> Help me out here guys...struts
post Mar 26, 2004 - 9:59 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
Im new to the celica world, so i need your expertise. I jus bought a coilover kit on ebay, and I figure I might as well replace the struts with new ones. My driving style is back and forth to work with some spirited turning when I run into some nice curves. I basically need to know what a good strut would be. I want to keep the price under 400, and will proabally do the install myself. Any advice? Also why do all 4 struts have 4 different part numbers?
thanks Madmods
Replies (1 - 13)
post Mar 26, 2004 - 12:30 PM
celimanST
Joined Nov 15, '03
From mississippi
I have been told tha KYB makes good struts but since I don't know from personal experience I can't give a good review.
William
post Mar 26, 2004 - 11:23 PM
mr_dude
Joined Feb 16, '04
From San Diego
I was under the impression coilovers were a strut and spring in a single piece... but they're out of my price range so I haven't done much research.
post Mar 27, 2004 - 12:17 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
Its a coilover kit on ebay.. about 75 bucks including shipping. You have to remove your stock springs to replace them with the springs in the kit.
post Mar 30, 2004 - 2:08 PM
celimanST
Joined Nov 15, '03
From mississippi
I was under the impression that coilovers are just the spring and the strut is thing that holds the shocks and where the spring sits.
post Mar 30, 2004 - 5:38 PM
Raek
Joined May 13, '03
From New Jersey
personally, i wouldn't have gone with a kit off of ebay...
if you want good, inexpensive struts/shocks...go with the KYB GR2's...
they've been great for me so far...
post Mar 30, 2004 - 6:08 PM
JKceli
Joined Apr 6, '03
From Gainesville, FL
KYB GR2 are basically OEM replacements
Koni yellows are the shiZ, but require some welding
GAB struts don't require any modification but you sure as hell won't find them for under $400.....
post Mar 31, 2004 - 11:23 AM
94GT
Joined Feb 25, '04
From Fairfield, CA
I just installed the KYB GR2s myself this weekend. Pretty good strut, and a little better than stock in my opinion. If you use it for going to and from work like me, that's pretty much the way to go. I'd recommend buying all the strut mounts as well (the front mounts come with bearings, the rears don't need them) new dust boots, (kybs come with an integrated bumper). If you buy from tire rack, you can get the boots (all four), two rear struts, two rear mounts, and two front cartridges. You'll have to get the other mounts from someone like Advance Auto (they carry the kyb front mounts) With pneumatic tools and a lift, this job still took me around 7 hours since it was my first time. I disconnected my brake hoses to get the struts out easier, so you gotta bleed the brakes, too. Good luck.
post Apr 1, 2004 - 1:03 PM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
QUOTE (JKceli @ Mar 30, 2004 - 11:08 PM)
The Konis shouldn't require any welding.
They do require that the rear struts be drilled and cut so that the Koni insert can be installed. It's something that's pretty straightforward (a little messy though) and explained fully by Koni. Almost any good shop could install them for you, if you don't have the tools to do it yourself.
post Apr 1, 2004 - 1:31 PM
CelicaQT
Joined Sep 29, '02
From Sterling Heights, Michigan
QUOTE (94GT @ Mar 31, 2004 - 11:23 AM)
Why did you bleed your breaks? You didn't have to do that? All you had to do was unscrew the breakline from the mount, and that's it. Then just slide your strut from the knuckle. biggrin.gif
post Apr 1, 2004 - 7:40 PM
BEEFSTEW800
Joined Dec 30, '03
From Atlanta
QUOTE (CelicaQT @ Apr 1, 2004 - 1:31 PM)
when you take loose a break line you need to bleed it to get out any air that got in.
post Apr 1, 2004 - 9:53 PM
Rjb23
Joined Feb 8, '04
From KY
QUOTE (BEEFSTEW800 @ Apr 2, 2004 - 12:40 AM)
You don't have to bleed it unless you disconnect the brake line from the caliper or open up the brake line in some way. Which is what I think that he meant that he did.
post Apr 2, 2004 - 10:30 AM
CelicaQT
Joined Sep 29, '02
QUOTE (Rjb23 @ Apr 1, 2004 - 9:53 PM)
Bcus when I did my suspension (GC's) we didn't do anything but unscrew the brakeline and we didn't bleed my brakes.
post Apr 6, 2004 - 1:31 AM
97GTinKC
From KC
QUOTE (CelicaQT @ Apr 2, 2004 - 8:30 AM)
I haven't looked at the celica, but on other cars, I have used a hacksaw to cut a slot in the brake line tab on the strut just wide enough to get the line out so I didnt have to open the brake system, makes things much easier...just be careful to NOT cut or damage the brake line.
Lo-Fi Version Time is now: September 23rd, 2026 - 6:14 AM
