> Installing a Fuel Pressure Regulator..., HOW???
post Mar 26, 2004 - 11:28 PM
94silverst
Joined Feb 20, '04
From Washington
Thanks 'mikedodson' for the equipment!! The only thing..... How do I install this?? I don't have any tubes, all the hard ware though. Does anyone know how to intall this??
post Mar 27, 2004 - 3:41 AM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
do you have an adapter for the old regulator or no? if not i can tell you how to get around the stock regulator & how to install it.... i have one
**edit
also, is it a rising rate adjustable fpr?
This post has been edited by toyotaspeed_90: Mar 27, 2004 - 3:41 AM
post Mar 27, 2004 - 9:21 AM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
keep the stock regulator there.. splice into the fuel line after it. it just T's in... ill explain it more in my how to. see my profile, u might be able to see some pictures to get a better idea.
post Mar 27, 2004 - 8:30 PM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
QUOTE (zipstrips @ Mar 27, 2004 - 2:21 PM)
why would you run the stock one w/o modifying it? at that point, you can't adjust the pressure any higher than the spring in the stock one will allow....... on the ST (4/7a-fe) the stock regulator sits on the fuel rail.... so you have to go through it unless you have an adapter (i went through it, but modified the stock one so that it can't regulate the pressure)
post Mar 27, 2004 - 9:45 PM
mikedodson
Joined Sep 30, '02
From san diego
You might try taking it to a local performance shop and see if they will tell you what you need. You only need a t-fitting and a few lines.
post Mar 28, 2004 - 12:13 AM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
you can get around the stock one & i know how..... if you let me know if you need to know how i'll tell ya....lol
Lo-Fi Version Time is now: July 7th, 2026 - 7:01 PM
