Mar 28, 2004 - 7:51 PM
Enthusiast ![]() ![]() Joined Apr 18, '03 From milwaukee, wisconsin Currently Offline Reputation: 0 (0%) |
well since my car died a few weeks due to the battery dieing, the same thing is happening now that did then. I'll try to explain it as best as i can. Somehow the door sensor is faulty or something similar to that because when i take the key out after the car is off and open the door everything seems to be fine but if i stay in the car and then close the door: the lights, door lights, Ac lights (not running just the lights) brake light (weakly glowing)and oil light are all still on. the only rememdy i have for this is taking off the battery termials or else some lights will be on. Also i can turn on my headlights if i want to as well with the car off. Well fooling around with the dome makes the brightness of the lights inside to go bright, to dim, to low and kinda flickering like. Does anyone know where the door sensor is located exactly so i can check to troubleshoot If someone else has had this problem or knows a solution i would greatly appreciate it. this is something i need to fix asap, like tonight. Also been raining here for like 4 hrs now and it doesnt seem to be stoping
Crzybakerdog PROBLEM Electrical is Draining the Battery Mar 28, 2004 - 7:51 PM
macavely when this happens is the key is on ACC, OFF . or o... Mar 28, 2004 - 11:21 PM
Crzybakerdog well the key is out of the ignition and the door l... Mar 29, 2004 - 12:00 AM
AudioFreak The door pinswitches are the plunger switches next... Mar 29, 2004 - 10:26 AM
Crzybakerdog no i dont have an alarm i have subs hooked up with... Mar 29, 2004 - 12:50 PM![]() ![]() |
| Lo-Fi Version | Time is now: June 24th, 2026 - 4:11 PM |
