Mar 31, 2004 - 12:33 PM
Enthusiast ![]() ![]() ![]() Joined Nov 15, '03 From mississippi Currently Offline Reputation: 0 (0%) |
I am curious about this swap how much would it cost??? I have not been able to find a 4A engine where could I get one??? What types mods would have to be done in the engine bay??? Do you guys have any info on this swap???
William |
Mar 31, 2004 - 1:12 PM
![]() Enthusiast ![]() ![]() ![]() Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) |
I'd ask coomer or John (Mynezyes or however u spell it), John but his 4agze in his self, its not currently running yet , and Coomer has a 4age in now that is running w00t!!!!
-Ryan -------------------- AIM : FAQdaWorld
Mar 31, 2004 - 6:05 PM
Enthusiast ![]() ![]() Joined Jan 22, '04 From bellingham, WA Currently Offline Reputation: 0 (0%) |
depends on which "4a" you want.... be it a 4a-ge 16V (low or high comp), 20V (silver or blacktop), 4a-gze (t-vis or non).....
Mar 31, 2004 - 6:14 PM
I am thinking of the 20V silver top. |
Mar 31, 2004 - 7:51 PM
although coomers is a success..... i gotta ask why? unless you plan on boost later, go for the blacktop (map) based..... it's a better all around motor..... coomer and I are neck & neck... all i have is a smallport 16V in my corolla...
Mar 31, 2004 - 7:56 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
blacktop is still incredibly overrated. not much more hp for alot more money. |
Mar 31, 2004 - 8:08 PM
I have been looking into it and the black top only has a minimal HP gain. Yes I do plan to boost later. William |
Mar 31, 2004 - 8:29 PM
why boost a 20v? its not built for it. go with a 4agze
Mar 31, 2004 - 8:33 PM
If you do plan to turbo the engine later, I'd say go for the black top if you're intent on having a 20V. If you're not, go 4A-GZE, assuming you can find someone competant to do the swap. The MAP sensor will work so much better than the AFM will when running a forced induction setup.
As far as cost, my total price for my entire swap, including labor, new stage one clutch kit and aftermarket lightweight flywheel, tons of replacement parts, the engine, tranny, ECU, belts, oil, filters, lines, etc. was around $3,000. As far as engine bay modification, the stock mounts should work fine. My front mount was a bit damaged and would've required modification, so my mechanic just fabricated a solid motor mount for the front. It's so awesome because the engine hardly moves at all now. You'll have to mount an external power steering fluid reservoir somewhere in your engine bay. Mine is on the passenger-side of the engine bay, close to the power steering pump. You'll have to use a longer throttle accelerator cable, because the stock one won't even come close to being long enough. If you've got more questions, just reply, and I'll do my best to help out. -------------------- New Toyota project coming soon...
Mar 31, 2004 - 9:26 PM
I do have one question if I was to do the swap could I do it in stages and replace the clutch a couple of months down the road??? The reason I am asking is that I read that the silver top 4A will run off of the stock trany at least for a little while anyway.
Mar 31, 2004 - 10:03 PM
here... this talks about the entire swap (from a 4a-fe to a 16V smallport 4a-ge.... will talk about similar issues as a 20V, but doesn't go over much wiring seeing how i used stock wiring & ecu)....
my complete swap cost me $1600 including: 4AGE motor, new flywheel, MSD 6al, MSD blaster 2 coil, MSD 8910 EIS tach adapter, KBD header, corolla GTS radiator (new), SARD adjustable fuel pressure regulator & gauge, new cap, rotor, spark plugs, oil, oil filter, belts, new KBD header, thermostat, radiator hoses, GTS gauges (from junkyard), & a couple sensors i had to buy, high flow cat, cat-back exhaust piping and exhaust done at a shop..... http://www.cardomain.com/memberpage/219038/9 even though the blacktop is map based and would be easier to work with boost.... the blacktop has lighter internals and it can't handle nearly as much as a silvertop can (which i've heard is lower than the 16V's can withstand... especially the gze which have partially forged internals)... you could also find a map based 4a-gze ae92 if you look close enough... which is pretty much optimum.... there's another silvertop car (an mr2) around here, which dyno'd at 120hp at the wheels... i put down 109hp at the wheels..... (just in comparison) between mine and coomers, i spent about $1400 less, have 4 less valves, ~200 rpm less, non vvt motor, but have a stronger head and easier to fix & upgrade (in the US) motor.... once you have the motor in, you can do what you want... your stock tranny (assuming your celica is an ST) will bolt up to any A series motor (probably even a 3a-c).... you won't need any custom mounts (although, if you go to a G head you need to bolt your 7a-fe motor mount bracket on the 4a-ge block instead of use the 4a-ge one... the upper part of the mount is slightly different and has timing cover clearing issues)... but as far as accessories read what i talk about in my above link.... i go into depth |
Mar 31, 2004 - 10:38 PM
Enthusiast ![]() ![]() ![]() Joined Feb 23, '03 From Florida Currently Offline Reputation: 0 (0%) |
So would a 4agze be worth it over a 7afe/3sgte swap, as far as cost, difficulty, etc...
This post has been edited by DmVinny: Mar 31, 2004 - 10:39 PM |
Mar 31, 2004 - 10:40 PM
in MY opinion yes a 4a-gze is a better swap.... it's easier to do, and the gze can handle quite a bit of power (esp. if you rebuild it)..... |
Mar 31, 2004 - 10:47 PM
Easier as far as??? do i still have to rewire the ECU? reason im asking the price difference between the 3sgte and 4agze is like $600 to $700...
Apr 1, 2004 - 12:05 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
Build up the 7a.
Apr 1, 2004 - 12:23 AM
Turboing a 4A-GZE correctly will probably cost quite a bit more than swapping in a JDM ST185 3S-GTE. Both engines are great, but in this case, I'd say the 3S-GTE is more cost effective. Also, it's been done before many times...there will be more people to help and it's a proven swap. -------------------- New Toyota project coming soon...
Apr 1, 2004 - 12:33 AM
why turbo right off the bat when you can swap the s/c pulley and have 12psi right at your hands with little other tuning..... |
Apr 1, 2004 - 12:50 AM
when you order a new engine does it come with a ECU??? Will you have to buy a new or have the original reprogramed???
Apr 1, 2004 - 1:39 AM
seems to me that it would be less cost effective turboing a 4a-gze if it came down to it since its more of a direct fit... still no answer about the ECU does that need rewiring... This post has been edited by DmVinny: Apr 1, 2004 - 1:40 AM |
Apr 1, 2004 - 3:06 AM
with a gze or a 20V yes, you will need the ecu that goes with the motor (if you can find a full 1/2 cut, which makes everything easier then the ecu is still in it) and you'll need the wiring....
if you want to run a 16V smallport, check my site and i'll lead you to the people to get your ecu tuned (and to still use your 7a-fe wiring) for ~$100 and you will be able to use the 7a-fe wiring |
| Lo-Fi Version | Time is now: August 27th, 2026 - 2:15 AM |
