Apr 12, 2004 - 7:44 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 25, '03 From cranston RI Currently Offline Reputation: 0 (0%) |
ok, im ordering a set of the z3 fenders, becuase mine are trashed and i need a cheap replacement... i dont like those vent things by the door. now ive never worked with this stuff, but i have had alot of experience with plaster on walls, and sanding that stuff down...
now is it basically the same thing? id glob the stuff on in the holes, wait for it to dry, then sand it smooth, right? like i said i do it to walls with spackle all the time, so it shouldnt be that hard... but is that basicially the steps? -------------------- ![]() |
Apr 12, 2004 - 7:50 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
No bondo! Cut out the vents, rough up both the front and back. In the back lay fiberglass cloth to cover the complete hole. Overlap the hole in the back. After it dries, cut fiberglass matt and fill the exact size of the hole from the front. Sand and finish up with a filler that has fiberglass strands in it. No bondo.
Its funny, because I ordered the z-3 fenders too, and Im going to cut the vents out and add some custom ones and get rid of the bottom vents. |
Apr 12, 2004 - 7:56 PM
but see, that requires a little bit more experience than i have.... i dont want to **** up my fenders, too poor for that... i have experience gooping stuff on and sanding it down....
why do you say no bondo? -------------------- ![]() |
Apr 12, 2004 - 8:16 PM
Enthusiast ![]() ![]() ![]() Joined Feb 23, '03 From Florida Currently Offline Reputation: 0 (0%) |
You can use bondo, but fiberglass is alot stronger...
With the bondo though your gonna have a rough time filling the whole unless u put sheet metal or grate behind it... so it doesnt sink in. But its basically glop some bondo on a piece of cardboard,etc. than add a bit of hardener stir, and apply... |
| Lo-Fi Version | Time is now: May 16th, 2026 - 9:51 PM |
