> k guys, i have a question, is this normal?, safc2 showing knocking at 10-15
post Apr 15, 2004 - 10:27 PM
forkee
Joined Nov 13, '02
From So Cal
engine has 4.75 quarts of mobil 1 synthetic oil
70k miles with no previous problems
running premium gas
boost is at 4-5 psi
i havent had a problem since the install last thursday, knocking was always 0-3, but recently it has spiked up to 20 at times. i was wondering if it was normal, and if not, how i can fix it.
thanks
post Apr 15, 2004 - 10:32 PM
snadman
From Minnesota, USA
wish I could help, it sounds like you shouldn't have a problem vbecause you're running such low boost and it has such low miles with no previous problems. Maybe some bigger injectors are needed?
This post has been edited by snadman: Apr 15, 2004 - 10:35 PM
95 Toyota Celica GT
Dead for now --> Soon to have a 3S-GTE
02 WRX --> This is for speed
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- MB Quart Reference 5.25" Components
- Rockford MTX 8" Subs in the doors
- Alpine Type S Rear Fills
- 2x Alpine SWR-1042D Subs in a custom fiberglass box
- Alpine F345 Amp for the front doors
- Alpine M605 on each Type R
- Phoenix Gold wiring
- Alpine CDA-9855 Head Unit
- Alpine Amp link
- 2x Rockford Fosgate 1 Farad Caps
- The best Viper 791 alarm install ever
post Apr 15, 2004 - 11:42 PM
ghostdog
From ny to philly
shouldn't be a problem. mine can go up to 30 when the engine is hot and I get on the throttle. what are your base knock settings? there should be one for 2500 rpm and 5500 rpm if I remember correctly.
post Apr 16, 2004 - 11:27 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
yeah, for running boost, thats low numbers, i wouldnt worry unless the numbers get higher and stay high
highest i got was just a little below 100, but that was at 8psi and WOT, and even then it was only for a split second then dropped to below 10(numbers skyrocketed the day the fuel pump gave out tho, 150+ sustained)
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Apr 17, 2004 - 9:11 AM
mikew04
Joined Feb 19, '04
From austin tx
What exactly is this measuring? Im not experienced at all with the safc2
post Apr 17, 2004 - 12:40 PM
SpedToe169
From Dallas, Tx
More importantly, what base timing are you running and when do you get the knock? Is it only at WOT or idling? Its normal for me to see values in the 8-13 range when the engine is really warmed up and is idling. I think its just hearing some of the internal noise of the engine with 130k of wear on it. Its not actually knocking at idle.
I would try dialing back the timing some, if it goes away, then it was actually knock and you probably had a bit too much timing in it. Also, when did you calibrate the knock monitor? The engine has to be really warm when you do it. I would say at least 30 minutes at highway speeds.
post Apr 17, 2004 - 1:10 PM
ghostdog
From ny to philly
QUOTE (SpedToe169 @ Apr 17, 2004 - 12:40 PM)
I've been curious about this. should I set it at wot? or reving the engine in neutral? I think they recommend the latter but that really doesn't represent real world conditions.
and I get 'knock' at idle but only when the safc has been sitting in the sun and has heated up. cheap japanese electronics, what can I say wink.gif
post Apr 17, 2004 - 2:47 PM
forkee
Joined Nov 13, '02
From So Cal
at cold start its at 0. after driving for awhile it goes up and fluctuates especially at WOT and then stays around 12. then if i turn the engine off then restart it start back at 0 but goes up slowly, even when idle...
Lo-Fi Version Time is now: June 10th, 2026 - 10:39 AM
