Apr 17, 2004 - 12:59 PM
Enthusiast ![]() ![]() Joined Dec 21, '02 From Orlando Currently Offline Reputation: 0 (0%) |
I've never gotten a good answer to this request, but I'll keep trying. I NEED to know the EXACT location of (I'm guessing I'll need to splice into the 2 ignition wires) the ignition wires to install my turbo timer on my 1994 ST. Thanks.
This post has been edited by XSTeknique: Apr 17, 2004 - 1:00 PM |
Apr 17, 2004 - 3:02 PM
just got done installing mine. took about 30mins.
the ignition wires are behind the panel the little alarm led/switch is in. then once that panel is off a smaller plastic panel that houses all the wires is removed. there are LARGE white wires in a certain wire loom. look for those its in that loom were the ignition wires are. i wish i could help u more. This post has been edited by x_itchy_b_x: Apr 17, 2004 - 3:03 PM -------------------- |
Apr 17, 2004 - 9:21 PM
Thanks...I'm guessing you're referring to the panal underneath the steering column. I guess it'll be some trial and error to figure out which ones they are.
Apr 17, 2004 - 10:07 PM
um blue with red stripe is 2nd igntion.
black with nothing is 1st ignition and red and black is + 12 v -------------------- |
Apr 18, 2004 - 5:05 PM
Thanks ALOT! You've been the best help yet!
| Lo-Fi Version | Time is now: June 23rd, 2026 - 8:12 PM |
