Apr 19, 2004 - 1:16 AM
Enthusiast ![]() Joined Feb 7, '04 From Calgary, Canada Currently Offline Reputation: 0 (0%) |
Where should I mount an aftermarket amp?
I'd perfer keeping the amp out of sight. Most amps won't fit nicely under the seats. If you put it in the truck, how did you mount it? Thanks! This post has been edited by mportobello: Apr 19, 2004 - 1:16 AM |
Apr 19, 2004 - 1:21 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 26, '03 From Wisconsin Currently Offline Reputation: 0 (0%) |
ive seen some mounted on the fold down seats
-------------------- i am awesome
Apr 19, 2004 - 2:00 AM
Enthusiast ![]() ![]() Joined Jan 22, '04 From bellingham, WA Currently Offline Reputation: 0 (0%) |
both of mine (and the crossover.... i used to have 2 crossovers when i had subs) are on my fold down 60/40 seats.... worked quite nicely
you can see a picture here: http://www.cardomain.com/memberpage/219038/4 |
Apr 19, 2004 - 3:34 AM
![]() Enthusiast ![]() ![]() ![]() Joined Sep 12, '03 From Portland , Oregon , United States Currently Offline Reputation: -1 (33%) |
![]() ![]() I Keep it Real. but you shouldent have a problem under the seats, that Pioneer fit easly under the seat, just gotta remember to have the seat back so its not seen. DTE -------------------- I am a thief.
do not buy anything from me. |
Apr 19, 2004 - 7:21 AM
Mine are mounted on the back of my fold down seats. -------------------- |
Apr 19, 2004 - 11:21 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) |
Yay for professional installation! (mine. hehe)
Apr 19, 2004 - 1:01 PM
Enthusiast ![]() ![]() ![]() Joined Nov 15, '03 From mississippi Currently Offline Reputation: 0 (0%) |
a custom amp rack is the way to because a properly installed amp can add alot to the interior of the car
william |
Apr 19, 2004 - 1:46 PM
under my driver side seat
Apr 19, 2004 - 4:22 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
mine is there as well, keeps everything really clean. its a pretty tight fit, but you cant tell its there unless you listen for or feel the fan i installed as well
Apr 19, 2004 - 4:43 PM
Enthusiast ![]() ![]() ![]() Joined Nov 18, '02 From Texas Currently Offline Reputation: 0 (0%) |
Mine's on the back of my seat too and sits behind my sub well.
Apr 19, 2004 - 11:39 PM
lol... you should put the professional installation in quotations.... my roommate is an installer and a "professional" and i won't let him touch my car's stereo |
Apr 20, 2004 - 12:11 AM
Do you mean a custom rack will improve the look of the interior? On my hatch, I'd like to keep the trunk and seat back clear so I can haul stuff around - I find all the trunk space a great feature. Has anyone made a false floor for the trunk. My trunk has the full size spare that makes the floor uneven. |
Apr 20, 2004 - 12:12 AM
Thanks for the replies. The pictures are great. Anymore?
Apr 20, 2004 - 4:36 AM
I guess its what is really to your taste, you have to take alot of things into mind also, if you want to show it all off, if you want to make it less-steal-able, and cooling. For the average person just mounting it to the back of the seat, or under the seats is a good Ideer, But if you like to show off, and enter shows and so forth it would be in your best intrest to make something 1off. If you were to mount under the seats or on the back, I would Run a relay setup that came on with your amp, and add some resistors so you dont get humming, because a Hot amp will useally be a dead amp. heres something I was throwing around with a friend of mine for his HB. Just replaces the top deck, A Amp, Distro Block, Cap, 1 12" Sub, and Under Glow Neon. Showie yet still having cargo room.
![]() DTE -------------------- I am a thief.
Apr 20, 2004 - 11:32 PM
How would a relay stop humming? What causes the humming? Too much heat? Thanks.
Apr 21, 2004 - 2:34 AM
It wouldent be the relay humming, The Relay is gonna click everytime it goes on and off, but thats with-standalble knowing that your amp isnt gonna be toast. I would add some resistors between the +12v coming off the relay to the fan, because even tho the fan is rated at 12v's when I had mine hooked up the Hummed because all the power, just throw in 50ohm resistor and should stop that.
DTE This post has been edited by Clipsetuner: Apr 21, 2004 - 2:34 AM -------------------- I am a thief.
Apr 21, 2004 - 2:51 PM
I used a 12volt fan as well, and the only thing i hear is the fan running, and the stereo volume has to be at 0, the car off, and no other outside noises. but i like having it under my seat... very clean, takes up no extra space, and if i want to show it off i just turn up the bass
Apr 22, 2004 - 1:24 AM
I sat in my back seat, an amp that is 12 x 10" will fit, but there is only just enough room to put my feet down. But then, I didn't buy the Celica so I could cart around passengers.
Apr 22, 2004 - 4:54 AM
![]() Enthusiast ![]() ![]() Joined Sep 6, '03 From Fairbanks AK Currently Offline Reputation: 0 (0%) |
hopefully this summer I'm gonna finish my system and make it pretty. i'm planning on recessing both amps into the back seats and building fiber glass enclosures to fit behind the rear wheel wells.
Apr 22, 2004 - 3:17 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jul 31, '03 From GA Currently Offline Reputation: 0 (0%) |
i have ![]() but i plan on complety redoing it this summer with 2 10's and an amp rack cormudgen |
| Lo-Fi Version | Time is now: August 4th, 2026 - 9:37 AM |
