Apr 20, 2004 - 11:33 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
Oscar(Pakeifier),
I am not sure if your rear bumper is going to fit my vehicle. Your pictures are from a hatchbackand I have a convertible which has to be based off the coupe. I know the dealers send coupes to ASC who cut them up and brace them up and make them convertibles. It seems like the lines are different. Does anybody out there know if theres differences in bodystyles between 94-95 and 96-99 coupes? It seems like there was a revised model in 96. Are the convertibles based off the coupes? I seem to notice 2 different type front ends not including the gt-4. My main question is about the rear. Are hatchbacks,coupes and convertibles different??? Does anybody with a convertible use a aftermarket coupe rear end Im sort of doing a different front end project like neverstops, but using a hundayi and invader front end. I bought a invader kit real cheap on ebay, and the rear came cut up. Almost like the previous owner ordered a kit from a hatchback for his coupe. Oscar, is there a rear bumper for the coupe/convertible? |
Apr 20, 2004 - 11:40 PM
Enthusiast ![]() ![]() ![]() Joined Nov 18, '02 From Texas Currently Offline Reputation: 0 (0%) |
There is a differnce between the coupe/vert and hatchback rears. Chances are good that the kit will fit the HB and not coupe/vert so it will need to be extended (I believe) in order to fit properly. The fronts are a little different also. There was a change made in '96 so they 94-95 are the same and the 96-99 are the same also. There aren't any differences between the fronts or sides between the coupe vert and hatch.
Apr 21, 2004 - 2:55 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
yup. the sides are a bit short and need to be extended. could be a real pain with a full bumper, but if you are fabricating you're own front I'm sure you can manage. |
| Lo-Fi Version | Time is now: August 27th, 2026 - 12:30 PM |
