Apr 26, 2004 - 6:44 PM
help... like i said, im gettgign a lil red light on my dash, it looks like the seatbelt thing, but theres a big ball on his lap... .. any idea, my guess is air bag or somthing'??/ an idea how to fix it.. thanks.
Apr 26, 2004 - 9:41 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 2, '03 From Annandale VA Currently Offline Reputation: 0 (0%) |
it is airbag, to fix it... umm.... get a diagnosis from your ecu
Apr 26, 2004 - 9:54 PM
well, i did have a friend help install an alarm, and thats when it came on, is there a wire or a plug that could of came un-pluged, or a blown fuse, even though tht sounds kinda stupid.. also my gauge cluster lights went out, im guessing a fues there too..
Apr 27, 2004 - 10:25 PM
ok, hoping that someone will still read this and help me out,... I talked to the guy that installed the alarm, and he said its most likly needs to be reset or somthing, that its prolly when it probed it check a curent, but the wires looked the same, but said it needed to be reset??? any clue? Thanks alot
Apr 27, 2004 - 10:37 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 25, '03 From cranston RI Currently Offline Reputation: 0 (0%) |
i get that... but thats becuse my airbags went off... im gonna just unplug the light
Apr 28, 2004 - 7:26 AM
im sure thats just gunna fix it, j/k.. humm but mine didnt, maybe il look into checking around today.
Apr 28, 2004 - 12:32 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 25, '04 From Wisconsin Currently Offline Reputation: 0 (0%) |
i dont wanna sound mean.. but you probably shouldn't of installed the alarm yourselves. i build computers and I wouldn't touch a good car alarm. (i know some of you people have and good job for you - dont flame). chances are you either unplugged power to the lights/sensors or cut into the wrong wires. I'd take it to your local stereo/alarm place and see if they know how to fix it. also, if it is a fuse.. there is a reason it went and it will go again unless the problem is fixed - just words of advice. hope everything goes well and it gets back working.
edit: also, change title to "airbag light on" or "gauge cluster backlight out" -just so people know what your talking about. This post has been edited by turboinduction: Apr 28, 2004 - 12:34 PM |
Apr 30, 2004 - 5:51 PM
Enthusiast ![]() Joined Nov 3, '03 From Iowa Currently Offline Reputation: 0 (0%) |
In some toyotas if the battery is disconnected with the key in any position other than off it will set the airbag light. Here it costs $65 to get it reset at the dealer. Good luck.
May 1, 2004 - 1:24 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 1, '02 From Minnesota, USA Currently Offline Reputation: 0 (0%) |
Or you could unplug the negative terminal on your battery for around 90 seconds maybe a bit mroe to be safe and put it bakc on...it will reset all warning lights and if there's actually something wrong it will come on again. I do this to my WRX as I installed a few aftermarket parts, as well as my Celi when I had the ABS light on...and then again on my parents' Mazda 626 with a swapped KL-ZE in it...sometimes something will just go haywire for a second and trigger a warning light to go on...you reset it and if there's actually something wrong it will come on again.
Such as with my WRX, sometimes the AFR signal will go haywire for some stupid reason as it goes thru the SAFC...or the EGR signal in my parents' KL-ZE...or as having a lot of brake dust covering the ABS sensor in my Celi...easy fixes. This post has been edited by snadman: May 1, 2004 - 1:27 AM -------------------- 95 Toyota Celica GT
| Lo-Fi Version | Time is now: June 12th, 2026 - 1:10 AM |
