> Fixed my idle rpm
post Feb 11, 2003 - 9:27 PM
hioctane
Joined Nov 26, '02
My friend fixed my idle rpm, so now it idles at 1000 =)
Replies (1 - 13)
post Feb 12, 2003 - 1:28 AM
94blackst
Joined Jan 20, '03
From Denver, co
Your idle is still a little high. It should be right around 800 to 850, or you could do damage to your transmission. Before you ask how it will damage your tranny, i'll tell you. When your idle is too high, and you put it in gear, you can, and eventually will, start taking teeth off the flywheel. You will also start breaking the bands in your tranny. You dont want to do that, so I would suggest having it lowered a little bit more.
post Feb 12, 2003 - 2:06 AM
hioctane
Joined Nov 26, '02
My car is an automatic, so i dont think it has a flywheel at all. Automatics tend to have a higher idle rpm than sticks
post Feb 12, 2003 - 10:26 PM
94blackst
Joined Jan 20, '03
From Denver, co
I understand that auto has higher idle, but manual is set at around 700-750, while the auto is set at 800-850.
as far as the flywheel, that was the wrong word. what i ment was the input shaft on the tranny. they do break if you have too much gas when you put it into gear. it can damage the torque converter also.
post Feb 12, 2003 - 10:45 PM
Cody
Joined Dec 11, '02
From Sioux Falls, SD, USA
Heh, yeah...every engine has a flywheel.
post Feb 12, 2003 - 11:01 PM
slowceli
Joined Oct 31, '02
From grants pass oregon
according to the chiltons repair manual tha 7afe should idle at 700 for both at/mt and the 5sfe should idle at 750 for both trannys. you might try resetting the ecu because it will adjust its self from when your friend changed your idle the first time.
oh yea on a manual trans it is a flywheel
on a automatic its called a drive plate
This post has been edited by burningcelica: Feb 12, 2003 - 11:03 PM
post Feb 12, 2003 - 11:03 PM
hioctane
Joined Nov 26, '02
how can i tell if i haven't already damaged my celi??????
What are some of the symptoms of having a damage torque converter??? I have notice problems some weird problems with my celica.
post Feb 12, 2003 - 11:04 PM
hioctane
Joined Nov 26, '02
to be exact my rpm idles at around 900
This post has been edited by hioctane: Feb 12, 2003 - 11:04 PM
post Feb 12, 2003 - 11:05 PM
hioctane
Joined Nov 26, '02
QUOTE (burningcelica @ Feb 12, 2003 - 9:01 PM)
how do i reset the ecu?????
What does the ecu looking like???
post Feb 12, 2003 - 11:10 PM
slowceli
Joined Oct 31, '02
just un do the positive battery cable for about 10 min. the ecu is the computer box under the carpet below the dash on the passenger side
post Feb 12, 2003 - 11:21 PM
slowceli
Joined Oct 31, '02
if you reset the ecu let me know if this works for you. i had a vacum line come of and it made my car idle at 1100 rpm's. put it back on and it idled at 400 reset the ecu and it idles right at 700.
post Feb 12, 2003 - 11:31 PM
hioctane
Joined Nov 26, '02
im goign to pull it out now brb.
post Feb 13, 2003 - 2:16 AM
hioctane
Joined Nov 26, '02
QUOTE (94blackst @ Feb 12, 2003 - 8:26 PM)
hey buring my alarm is weird now. I unplugged all the wires from the positive battery. So now two sirens from my alarm goes off. one normal and one i never heard before (POLICE SIREN)
post Feb 13, 2003 - 2:18 AM
hioctane
Joined Nov 26, '02
does the siren go off when you plugged the wires back onto the positive part of the car battery?????
I can't start my car becasue the the alrarm disables the car.
Lo-Fi Version Time is now: July 30th, 2026 - 6:53 PM
