Apr 29, 2004 - 5:31 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) |
CelicaDeath, just because you didn't understand at first what I was saying, doesn't mean it's not true.
As you pointed out (after looking it up I assume), Subs with underpowered amps are much more likely to be damaged when the gain knob is cranked. Without all the technical stuff added in, it goes to this: If you underpower a sub, it will more likely be damaged than it would be if you have too much power going to a sub. Subs are damaged more by too little power, than by too much. I stand by that statement, and your own second post proves me right- it's not a huge stretch |
Apr 29, 2004 - 8:00 PM
Enthusiast ![]() Joined Apr 1, '04 From Iowa Currently Offline Reputation: 0 (0%) |
WHY will a sub be more damaged when underpowered then too much power?????
You still haven't answered that question. And no I didn't look it up, its common sense. |
Apr 29, 2004 - 8:18 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 25, '02 From Pittsburgh/Clairton, PA Currently Offline Reputation: 1 (100%) |
ummm, riight. -------------------- ![]() |
Apr 29, 2004 - 8:54 PM
Them solos can take 500w+ just fine, no matter what the box.....I still vote for the brutus
Apr 29, 2004 - 8:59 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 23, '03 From New Orleans Currently Offline Reputation: 5 (100%) |
dont try to do that much on those 8s. My manager had four 8SL7s on 2000 watt amp, i believe its 2 channel so 2 subs off a channel, and blew 3 of them. find an amp that runs 400 RMS and wire them to match the amp.
& overpowering at continous (RMS) is just as bad as overpowering at MAX. This post has been edited by chucho: Apr 29, 2004 - 9:01 PM |
Apr 29, 2004 - 9:00 PM
Uhm, you explained why less power is worse yourself in the second post you made-
It's simply that you're more likely to damage the sub when you're using an underpowered amp. |
Apr 30, 2004 - 6:48 AM
Install error kills subs, kids crank the gain knob with both underpowering and overpowering subs. But when gains set right, more power is worse. |
Apr 30, 2004 - 7:53 AM
Enthusiast ![]() ![]() Joined Dec 19, '02 From West of Atlanta Currently Offline Reputation: 1 (100%) |
I was refering to each sub being wired to 2 ohm. Not the total of both. Yes there are better SQ subs out there. I was refering to the fact that solos can sound pretty good (for an spl sub)in the right box. While in the wrong box they are really loud but really boomy. MDF is medium density fiberboard. Available at lowes and home depot and such. Around $20 a sheet. |
Apr 30, 2004 - 9:00 AM
awesome! thank you...
i little disappointed to hear solo barics are not considered good, i heard they were... i only have 1 more q, but i have a final in an hour. i have to study -------------------- ![]() |
Apr 30, 2004 - 9:56 AM
The SL7s are good all-around subs for their money. If you have the right set-up they'll hit clean and crisp.
I have a KX600.1 to each of mine and i've had plenty of compliments on how clean they hit, but that is also w/ the amp turned down and on vocal on my cd player. When their cranked you cant hear anything else other than bass lol. But even turned half way up they have a clean hit. Just make sure you buy some dynamat while your at it. |
Apr 30, 2004 - 11:46 AM
Wait a sec, I didn't say L7's are bad, they just have moderate at BEST sq. It's hard to get louder than an L7 for the same amount of money. L7's are loud, but don't buy them for a SQ install........ |
| Lo-Fi Version | Time is now: August 25th, 2026 - 5:26 AM |
