May 2, 2004 - 1:28 AM
![]() Enthusiast ![]() ![]() Joined Jul 6, '03 From Long Beach, CA..."LBC" Currently Offline Reputation: 0 (0%) |
mono amps means one chanel rite?....i have the amp above, i believe its made by viper audio. well anyways it has 2 channels to it and i was told i wasnt to bridge it because it bridges itself internally also said in the manual. so i running 2 12's (crossfire db's) one into each channel. i was wondering if i can run both into one channel and maybe get a lil more power. its rated at 200rms x 1 at 4 ohms and 300rms x 1 at 2 ohms. the subs are SVC at 4ohms. well thats it for now thanks!!
sang -------------------- |
LBCxGUY directed audio 350d mono block May 2, 2004 - 1:28 AM
LBCxGUY mono block help anybody?? May 3, 2004 - 11:10 PM
phat94celi are you sure thats the amp you have? Because bein... May 4, 2004 - 5:16 PM
shid I have a question VERY related to this too. I have... May 4, 2004 - 7:57 PM
BEEFSTEW800 both of you are running your subs at 2 ohms. the 2... May 4, 2004 - 8:32 PM
shid I'm not running at 2 ohms- I KNOW I'm not ... May 4, 2004 - 8:35 PM
Yobbe 2x 4Ohm woofers in parallel equals 2 Ohm
So you ... May 5, 2004 - 6:58 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 26th, 2026 - 6:54 PM |
