> oil light flickers, when idling in gear
post May 2, 2004 - 8:22 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
does anyone know how to fix this? It only does it at low RPMs but it would feel like a rigged solution if i just raised the idle, right now its at like 6-7 hundred rpms
post May 2, 2004 - 10:44 AM
forkee
Joined Nov 13, '02
From So Cal
put more oil?? lol
post May 2, 2004 - 11:19 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
oil pump is on its way out, better replace it fast, unless you want to replace the whole engine
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post May 2, 2004 - 8:47 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
are you sure? in the readers manual it says flickering at idle is no problem
post May 2, 2004 - 11:30 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (brianforster @ May 2, 2004 - 5:47 PM)
its really in the manual?
thaty doesnt make any sense, when the light is off is when things are good.
just in case, take it to a dealer and see what they say
post May 3, 2004 - 12:08 AM
macavely
Joined Nov 4, '02
do you have a 5spd .. cause it be happing cause the car might be about to shut off.. do anyone lights come on?
post May 3, 2004 - 3:44 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
What is happening is the idle dipping down doesnt send enough power to the alternator which in turn cant keep the oil pressure up.
Dont know how to fix it but thats the explanation my friend gave me
post May 3, 2004 - 3:55 PM
SpedToe169
From Dallas, Tx
The oil pump is driven mechanically off the rotation of the engine. Oil pressure has absolutely nothing to do with the alternator or electrical system.
What 97ss said is right. The light only comes on when the oil pressure is below a certain level. If your oil pressure is below that level, even at idle, there is a problem.
post May 3, 2004 - 4:02 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
ok I am grateful for your help but the manual says on page 48:
"The light may occasionally flicker when the engine is idling or it may come on briefly after a hard stop. There is no cause for concern if it then goes out when the engine is accelerated slightly."
post May 3, 2004 - 8:46 PM
Junior
Joined May 5, '03
From Toronto
I would still worry. And idleing at 600 rpms is kinda low.
post May 3, 2004 - 9:15 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
should I just raise the idle?
post May 3, 2004 - 10:02 PM
Hanyo
Joined Aug 16, '03
From Bay area
I would rise the idle 600 is really low.
try turning on your air conditioner at idle and see if it the engine starts to shake.
post May 4, 2004 - 6:04 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
yeah it does hanyo it kind of sputters?
post May 4, 2004 - 6:25 PM
DustyBurns30
Joined Jul 31, '03
From Panama City Beach, FL
the oil light started doing that to me at idle and occasionally when i braked. a little while later it threw a rod. a new oil pump is not that expensive neither is the oil pan gasket or high temp RTV.
just thought i would let you know my experience.
Lo-Fi Version Time is now: August 2nd, 2026 - 2:15 PM
