May 2, 2004 - 10:16 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 26, '03 From Wisconsin Currently Offline Reputation: 0 (0%) |
im blowing fuses and im tracing down simple problem by problem where everyones got their stuff.
i have a 100a wafer fuse in front that is NOT blowing, then i have it into a distrb. block which im using for 8 ga. to the amp. the fuses are 60a blowing in the dstrb block. the ground isnt great but it should work (yes its 4 ga.) they blow even when the amp is turned down. i also have the two smaller fuses in the amps 5 more amps then they should be. (25 instead of 20) -------------------- i am awesome
Andason blowing stereo fuses May 2, 2004 - 10:16 PM
Digndoug Hey, im kinda having the same problem, something a... May 2, 2004 - 10:20 PM
Andason QUOTE (Digndoug @ May 2, 2004 - 9:20 PM) Hey, im k... May 2, 2004 - 10:21 PM
AudioFreak QUOTE (Andason @ May 2, 2004 - 11:16 PM) im blowin... May 3, 2004 - 11:17 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 25th, 2026 - 10:35 PM |
