May 4, 2004 - 2:57 PM
![]() Enthusiast ![]() ![]() Joined May 4, '04 From Panama City Beach, FL Currently Offline Reputation: 0 (0%) |
I was wondering if anyone else has run into the problem of their fuel door latch and trunk latch not working and what they did to remedy the situation?
The Fuel door still unlocks with the switch, but doesnt pop open. Good thing I have long arms and can manually pop the door while pulling the switch on the floor to unlock it, but it would be nice to know how to fix that. The Trunk floor latch broke off and now the only way to open the trunk is by hand. The 94 coupe is not the most convienant thing to open when you have no real handle to open the trunk with, so fixing the popper would be nice. Maybe I'll put it on a remote. Anyone ever done that, or fixed the original problem before that can give me some advice? Thanks. -------------------- ![]() |
May 5, 2004 - 12:31 AM
![]() Enthusiast ![]() ![]() ![]() Joined Sep 12, '03 From Portland , Oregon , United States Currently Offline Reputation: -1 (33%) |
the easyer way would be a remote setup for both, and for the gas cap just put it under the dash. When I picked up my Celica, Neither worked For the trunk, where the cable meets the Key popper in the back, The Key popper stoped it from moving because someone had tried and broke into it. I Zipped tied the whole unit up good with about 10 of them, and to this day It still works so no complainets.
DTE -------------------- I am a thief.
do not buy anything from me. |
May 5, 2004 - 12:46 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
there is a spring that pushes the fuel door out.
try to put a generic spring on the door so it can push out when u pull the lever.. about the trunk .. Install an ebay trunk popper, i put one in for my alarm and its costed about 18 bucks shipped... is pretty easy... i would recomend drilling holes instead of using zip ties.. If I had access to my car i would show u how i mounted the system. |
May 5, 2004 - 1:22 PM
Enthusiast ![]() ![]() ![]() Joined May 15, '03 From Aurora IL Currently Offline Reputation: 0 (0%) |
Your trunk not working could be the Valet switch on the trunk itself.
If you put the key in the trunk lock, then make sure it's | vertical like that, thats just regular operating mode, you can open it via the latch. If it's horizontal --- , I think that's valet mode, and that wont allow the latch to open the trunk. I might have it switched around, but check that out first before you decide to go waste your money on a trunk popper. |
| Lo-Fi Version | Time is now: June 10th, 2026 - 8:47 AM |
