May 5, 2004 - 7:10 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
The first has these options,
4 -button extended range transmitters Two-way remote controller with page LCD display On board relays for starter disable, flashing parking lights, Positive / Negative door lock outputs Switch sensing Auto rearming Remote panic Build-in relay for power door lock Plug-in sensor ports Visual and audible indication on arm and disarm Safety RF lockout Car Locator Plug in override switch/ LED Keyless entry Zone memory indicator (door open) Plug in shock sensor Last door arming Non-volatile Multi-code Memory Power up memory Active/passive arming Door lock output time (.75 or 3 sec.) Passive door locking capability Auto rearm feature (Enabled/disabled) Silence arm and disarm Warning for unlocked vehicle Warning for disarmed vehicle Triger for memory and report Anti-Hijacking Remote Engine Start / Stop Remote Control Turbo Cool Down Mode Two-way transmitter Long distance range:950-3300m Detecting movement inside and oursie the vehicle Red light blinking alternately Super long distance transmitting range Color LCD remote displaying the status of vehicle Alarm with sound, tremble and color logo by remote controller The second has these options, *Two, 4 button High Frequency Remote Transmitters * Window mount extended range helical transceiver antenna module * Remote car starter with 5 on-board relays and all the features of the RS-650 * 66 Bit Random Code Hopping * Code Learning / Anti-scan Receiver * Back-up Memory System * Dedicated Remote Panic and Car Locator * Dual stage shock sensor * Pre-warning indicator * Passive Arming By-pass from Remote * Parking Light Flash Dual Polarity (relay on-board) * 2nd Channel Auxiliary Output * Plug-in Push type Valet/Override Switch * Plug-in Super Bright LED * Starter Disable Output with Relay & Socket (included) * Dome Light Illuminated Entry * 1 Positive, 4 Negative Inputs * Error By-pass Reporting * 120 db Electronic siren * Horn Honk Output * Ground When Armed Output * Dual Polarity (+/-) Door Lock Outputs * Drivers Priority 2 Step Unlock * All Programmable Features are Programmed via the Remote Transmitter REMOTE START FEATURES * 5 On Board Relays * Ignition 1 * Ignition 2 * Starter * Accessory * Parking Light * 3rd Ignition Output * Ground When Start Output * Diesel Fuel Compatible * Hood Safety Pin Switch Input * Selectable Voltage / RPM Start Sensing / Timer Start * Timer Start Control (.6 seconds - 4 seconds) * Temporary Stop Feature * Factory Security Disarm & Rearm outputs * Programmable 3 Hour / 24 Hour Timer Start * Sensor Control Output During Start * OEM Alarm Output * Selectable Run Timer * Ignition Control Lock By-pass During Remote Start PROGRAMMABLE FEATURES * Chirp Delete * Manual / Passive Arming * Passive Arming Door Locks * Ignition Control Door Locks * Automatic Re-arm * Single/Double Pulse Unlock * Pathway Illumination * Voltage Sense/RPM Sense/Timer Start * 5,10,20,30 Minute Run Timer * Gasoline/Diesel Engine type * Lock-Unlock Output Timing (.9-3 sec.) * Factory Disarm/Rearm |
Rjb23 Which of these 2 alarms would you choose May 5, 2004 - 7:10 PM
Doge I would go by reviews of each product rather than ... May 6, 2004 - 1:23 PM
Drocay and what company produces them? It might have all ... May 6, 2004 - 1:29 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 26th, 2026 - 7:08 AM |
