> 2 Questions, audio and interior
post May 5, 2004 - 10:49 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
1) Can a 8" sub and a 12" sub be in the same box? (please try to give an idea of where to go to find box building for this idea if possible)
2) What can i use to get the paint of my interior dash pieces (the plastic inserts) without damaging the plastic?
post May 5, 2004 - 11:16 PM
celimanST
Joined Nov 15, '03
From mississippi
well I would put two subs of any kind in a single box. You can use XIM clear primer and you should be ok I don't that will damage the plastic.
William
post May 6, 2004 - 2:19 PM
mikew04
Joined Feb 19, '04
From austin tx
just have each speaker in a seperate (correctly sized) compartment and you'll be fine
post May 6, 2004 - 8:48 PM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
Why do you need to get the paint off?
post May 6, 2004 - 10:32 PM
Consynx
Joined Dec 25, '02
i want a different color
i have red, and want a dark grey...less stand-out
post May 6, 2004 - 11:01 PM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
Then you shouldn't need to strip the paint. Just sand it and repaint it over top the original coat. Paint adheres to paint as long as it's been scuffed up enough.
post May 6, 2004 - 11:11 PM
Consynx
Joined Dec 25, '02
id rather take off the paint, if anything where to chip i don't havce to worry about having 2-3 colors under it, just plain black plastic smile.gif
post May 7, 2004 - 6:52 AM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
Well do what you like. It's just that I do this type of thing for a living and I know to do that is just asking for trouble. By the time you find something strong enough to remove the paint you'll deform the plastic. It's very risky. And if you do a good job painting over the original color it won't chip. Is the original coat chiping or something? Cuz that could cause some probs.
Ryan
post May 7, 2004 - 9:16 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
if u are that worried then just sand it down to the black plastic might be more work but it will get u what u want without ruining your pieces.
Team 6gc 2005
post May 9, 2004 - 10:29 PM
celimanST
Joined Nov 15, '03
From mississippi
William
**** WOULDN'T *****
sorry about that
post May 11, 2004 - 2:50 AM
creis
Joined Jan 10, '04
From Shoreline, WA
as for the 8" and a 12" if there in a same enclosure space, the 12" will suck the s**t out of the 8" maybe even implode the cone. depending on how much power each has, its a bad idea. but there fine if in separate space, even if its one box, just must be split into 2 separate sections, with the right amout of volume for each sub.
post May 11, 2004 - 3:07 AM
macavely
Joined Nov 4, '02
answer for question 2 ... don't use any thing that will strip paint.. i did that on my ST and really F'd up the inserts... plastic doesn't like checmicals that strip paint.. just do want everyone say.. sand down a little and repaint.. just put a black base coat first.. then paint then clear coat.. you shouldn't have any problems with chipping paint..
answer to 1st question... just like mikew04 said.. do like those hose speakers that come with the 18 inch and 12 inch sups on them... just have the bigger sup just a little lower then the smaller one...
Lo-Fi Version Time is now: August 27th, 2026 - 11:33 PM
