> Fiberglass question, how to cut
post May 9, 2004 - 9:48 AM
gtcelica94
Joined Apr 4, '04
whats the best tool to useto cut little holes in it. im new to fiberglass and dont want to break it. and can you copy fiberhglass. exmple like can i make an exact copy of this peice if so how ? thank
This post has been edited by gtcelica94: May 9, 2004 - 9:49 AM
Replies (1 - 10)
post May 9, 2004 - 9:53 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
i use my Dremel and it seems to work realy good.
to make a copy u need to make a mold but i don't know how so i wont turn u in the wrong direction.
Team 6gc 2005
post May 9, 2004 - 5:33 PM
Rjb23
Joined Feb 8, '04
From KY
To make circular holes use a hole saw, you can get it any hardware store. It is a drill bit with a circular saw on it and you just drill slowly and it cuts a hole.
For like squares and stuff use a dremel tool with reinforced cutting wheel.
post May 9, 2004 - 6:11 PM
PhillyGuy086
Joined Sep 18, '03
From Dirty Jersey
i used a dremel with either the cutting wheel or the sanding barrel... both worked great. i did the primary cutting with the wheel and cleaned it up with the barrel.
post May 9, 2004 - 6:16 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
drill bits work just fine for small stuff wink.gif otherwise use a large diameter drill bit.. basically what Rjb23 described.. if your looking to really large holes like for a speaker or something then you will need a router which you can pick up for 50+ from a hardware store.
as for the molds.. there are tons of differnt ways to do it.. if you had a pic of the item you wanna copy it would be easier to tell you which way to use
post May 9, 2004 - 6:37 PM
Junior
Joined May 5, '03
From Toronto
To make a mold you can take the piece and spray mono insulating foam all over and then pull it off. line the mold with alluminum foil and then start fibreglassing. Do a search on fiberglass basics. Someone please confirm this is a good way.
post May 9, 2004 - 7:09 PM
gtcelica94
Joined Apr 4, '04
i can use drill bits i heard i couldnt, im just trying to drill out the little holes to go into my splitters, so im guessing a dremel.
mono insulating foam will this mess up my peices, will it pop tight out or will it stick to it
post May 9, 2004 - 11:37 PM
crazy95
Joined Dec 23, '03
there is a few different ways to make a mold... like said before you could use the insulating foam or just line the piece that u want to copy with either masking tape or duck tape.. apply the first layer of fiberglass and then pull it off and work from there... the tape comes off fairly easy... with masking tape u may not be able to get it all off
chris
post May 9, 2004 - 11:45 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
first cover your piece with aluminum foil and then do the foam. it will slide right out when your done.
Team 6gc 2005
post May 9, 2004 - 11:48 PM
gtcelica94
Joined Apr 4, '04
ok i think i got it now . one last question where can i get that foam or whats the name of it
post May 11, 2004 - 12:46 PM
Junior
Joined May 5, '03
From Toronto
just go to home hardware or home depot or wherever Americans go for their home building needs. It insulating foam in a can. MONO makes one and i'm not sure of other brands.
Lo-Fi Version Time is now: July 30th, 2026 - 2:56 PM
