May 18, 2004 - 2:03 AM
![]() Enthusiast ![]() Joined Mar 2, '04 From Little Rock, AR Currently Offline Reputation: 0 (0%) |
ok, so the 7afe head uses a different style of rocker arms, right? my head has a real bad tick when i shift a certain way, when i hold the gas half throttle, or when im accelerating over 4500 rpm. anyone ever had similar problems?
titaniumkid 7afe head May 18, 2004 - 2:03 AM
van95st first off overhead cam engines do not have rocker ... May 18, 2004 - 2:44 AM
97GTinKC QUOTE (van95st @ May 18, 2004 - 12:44 AM) first of... May 18, 2004 - 11:18 AM
titaniumkid the noise has stayed at a consistant volume, and i... May 18, 2004 - 8:15 PM
Kwanza26 QUOTE (titaniumkid @ May 19, 2004 - 1:15 AM) the n... May 18, 2004 - 8:41 PM
titaniumkid well i thought it could be a rod bearing or rod kn... May 18, 2004 - 9:22 PM
95STHATCH Sounds like it's rod knock or your bearings to... May 18, 2004 - 10:02 PM
FallenHero it's while you're giving it pedal right? ... May 18, 2004 - 10:34 PM
titaniumkid yeah, exactly! how much did you get the belt f... May 18, 2004 - 11:42 PM
FallenHero the belt itself is cheap, but I had it installed. ... May 18, 2004 - 11:57 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 27th, 2026 - 7:38 AM |
