May 24, 2004 - 11:03 AM
Enthusiast Joined Aug 30, '02 From Fort Smith Arkansas Currently Offline Reputation: 0 (0%) |
I changed my battery and now my light is on, do i need to reset something?
May 24, 2004 - 11:41 AM
Enthusiast ![]() ![]() ![]() Joined Apr 4, '04 From VA, USA Currently Offline Reputation: 0 (0%) |
reset ur ECU
May 24, 2004 - 12:36 PM
Enthusiast ![]() ![]() ![]() Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
altenator could be gone
May 24, 2004 - 1:51 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 12, '03 From Chatham, Ont Currently Offline Reputation: 0 (0%) |
Did you charge the battery?
May 24, 2004 - 3:27 PM
How do I reset the ECU |
May 24, 2004 - 6:58 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Make sure your battery cables are tight, and make sure you have good contact at your alternator.
May 24, 2004 - 8:49 PM
Enthusiast ![]() ![]() Joined Mar 2, '04 From Louisiana, USA Currently Offline Reputation: 2 (100%) |
If you had the cables off of the battery for more than a few seconds while you were swapping batteries; the ECU is reset. No need to do it again, a bad alternator or connections are more than likely your problem. |
May 26, 2004 - 11:07 AM
Enthusiast ![]() ![]() Joined Apr 7, '04 From Toronto Currently Offline Reputation: 3 (100%) |
your problem is the alternator.
you have to change it w/ new or used. |
| Lo-Fi Version | Time is now: May 18th, 2026 - 12:07 PM |
