May 25, 2004 - 7:34 PM
Enthusiast ![]() Joined Mar 28, '03 Currently Offline Reputation: 0 (0%) |
Im just wondering what you guys use for aftermarket spark plugs and spark plug wires. If anyone can tell me what kind and where you got it, and also if theres any difference between aftermarket and stock, let me know. Thanks a bunch!
May 25, 2004 - 9:09 PM
Enthusiast ![]() ![]() Joined Jun 21, '03 From FRANKFORT,KENTUCKY Currently Offline Reputation: 0 (0%) |
I've always used ngk plugs for toyotas i've owned. Don't go with bosch platinum.
May 25, 2004 - 9:13 PM
Enthusiast ![]() ![]() Joined Mar 2, '04 From Louisiana, USA Currently Offline Reputation: 2 (100%) |
I have Magnecor 8.5mm wires and Denso Iridium plugs. Got them both from a vendor I sued to work for, beacuse I could get them cheap.
Copper plugs are generally what I recommend if you need new ones. I know a lot of people on 6gc have NGK wires, I used to have a set on my '95... No problems; I upgraded after using them for 5 years due to the boots being burnt through. |
May 26, 2004 - 2:20 AM
![]() Enthusiast ![]() ![]() Joined May 4, '04 From Panama City Beach, FL Currently Offline Reputation: 0 (0%) |
I just put on NGK wires and Bosch Platinum 4 plugs. No problems and its running smooth. Only on for a week though. 95STHATCH, why do you not like the Bosch? You should be able to find them easily on the net somewhere. NGK wires ($60) Plugs, distributor cap, and rotor ($40) This post has been edited by Tweek: May 26, 2004 - 2:21 AM -------------------- ![]() |
May 26, 2004 - 12:58 PM
![]() Enthusiast ![]() Joined Jan 28, '03 From underground Currently Offline Reputation: 0 (0%) |
trd and denso irid work great for swaps.. it helped XST.
This post has been edited by Mr7AFE: May 26, 2004 - 12:58 PM |
May 26, 2004 - 1:50 PM
Enthusiast ![]() ![]() Joined Jan 22, '04 From bellingham, WA Currently Offline Reputation: 0 (0%) |
custom length Accel wires (one coil wire already melted internally from the MSD) with NGK plugs on the ae92
whatever was on the car wires (good shape) and NGK plugs on the aw11 |
Jun 2, 2004 - 10:32 AM
where to get NGK wires?? Cheapest place?
Jun 2, 2004 - 10:57 AM
Denso Iridium Plugs are probably the best.
http://www.sparkplugs.com/default.asp Probably get them for a good price there, and some Magnecore wires |
Jun 2, 2004 - 12:58 PM
Enthusiast ![]() Joined Aug 17, '03 From Bangkok, Thailand. Currently Offline Reputation: 0 (0%) |
I'm using customized Split Fire wires with HKS iridium S40i plugs.... so.. so...
didn't notice any change much from the stock wires. |
| Lo-Fi Version | Time is now: August 28th, 2026 - 8:49 AM |
