May 26, 2004 - 4:16 PM
Enthusiast ![]() ![]() Joined Mar 31, '04 From Cincinnati, OH Currently Offline Reputation: 0 (0%) |
I've used the search function and found some information, but I figured I'd post my questions specifically. Alright so I have Ground Controls, along with new KYB GR-2s. Neither are installed yet, going to wait for wheels and do it all at once. My question is, since i'm re-doing all this, i'm assuming it'd make sense to buy new boots and mounts, along with other small parts that may be worn out. Now where do you recommend I buy my strut boots and mounts, and whatever else I may need?
Thanks in advance! Ryan |
May 26, 2004 - 4:28 PM
![]() Enthusiast ![]() Joined Nov 17, '02 From Mission Viejo, CA Currently Offline Reputation: 0 (0%) |
when i got my GR-2's off of Tirerack.com, they also had strut boots you could buy. I dont know about the ground controls though. But tirerack.com is an option.
May 26, 2004 - 10:10 PM
Enthusiast ![]() ![]() ![]() Joined Aug 21, '03 From Endicott NY Currently Offline Reputation: 0 (0%) |
tirerack suggests that you buy 4 boots, you will only need 2 because to front 2 are attached to the strut and the ones you have will work better unless they are really beat up. I also had my sway bar bushing replaces, and you will need a camber kit and and alignment.
May 27, 2004 - 7:22 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) |
you wont need a camber kit unless you plan on dropping the car a ton! The factory adjustments are plenty for most moderate drops.
May 27, 2004 - 2:19 PM
I need the camber adjustment for my intrax springs and they're only 1.75"
| Lo-Fi Version | Time is now: May 25th, 2026 - 6:50 PM |
