> egr, what makes it legal?
post May 26, 2004 - 5:20 PM
celicasupra209
Joined Mar 30, '04
From cali
Where can i find a place to put that into a jdm if i purchase that?
RIP-1995 Toyota Celica GT
Riding a 2002 Honda Civic HB Si
post May 26, 2004 - 8:33 PM
its not possible to add it on.
post May 26, 2004 - 10:12 PM
3FingersCelica
Joined Aug 21, '03
From Endicott NY
QUOTE (lagos @ May 27, 2004 - 1:33 AM)
Anything's possible but it will cost a fortune. I know if you import a car they need to put a EGR system in to make it legal to come in the US.
post May 26, 2004 - 10:26 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (3FingersCelica @ May 26, 2004 - 7:12 PM)
yea, but they require more than just EGR.
for a 2nd gen 3sgte, the USDM EGR parts will bolt right on. it will still be expensive, and a lot of parts to source.
just setup a fake one and run a bottle of surepass when you test the car(have a good high flow cat as well)
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post May 26, 2004 - 10:27 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (3FingersCelica @ May 27, 2004 - 3:12 AM)
Won't cost a fortune... you just need USDM parts. USDM intake and exhaust manifolds with EGR parts (lines, etc...) depending on whether the JDM ones have pre-drilled spots for the EGR system... however, once you change the manifolds (if need be) there may be other stuff to change.
This post has been edited by Kwanza26: May 26, 2004 - 10:28 PM
post May 27, 2004 - 10:46 PM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
wth are you guys talking about... just use the USDM manifolds and the USDM egr setup that should already be in the car......
post May 27, 2004 - 11:19 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (toyotaspeed_90 @ May 27, 2004 - 7:46 PM)
the egr setup in a usdm 6gc will not work on a 3sgte
post May 28, 2004 - 3:15 AM
Doge
Joined Dec 2, '02
From Portland, Oregon
Can you make it LOOK like it will work though?
post May 28, 2004 - 11:23 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (97sccelica @ May 28, 2004 - 4:19 AM)
I think he meant use a USDM 3SGTE EGR system... which should still function assuming you have it all on correctly.
post May 29, 2004 - 1:27 AM
Chrobis
Joined Apr 15, '03
From San Jose, CA, USA
umm you would also need the USDM ECU and USDM wiring harness.... An EGR system is not purly mechanical :-P
Lo-Fi Version Time is now: August 25th, 2026 - 3:04 PM
