> Where is the Engine Diagnostics Plug, Not the one in the engine bay
post Jun 1, 2004 - 5:28 PM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
Does anyone know where the plug is on the inside of the car that you can plug a computer into and it tells you everything going on with the car?
I thought there was a connector under the steering wheel and i looked and there was not one there????
Do we even have one of those plugs on the 6g celica?
I remember having one on my other car but it was not a toyota.
If anyone knows sent me an email please on its location!
thanks,
dg
Replies (1 - 9)
post Jun 1, 2004 - 6:08 PM
Even if we did, u have a swap, it wouldnt work.
They hook it up to the diagnostics box in the engine bay, thats what the ECU is connected too.
post Jun 1, 2004 - 6:21 PM
should be right above your gas pedal, but i doubt it will work on a swap celica.
its not on all celicas tho, my 98 has it, but some early 6th gens dont. in fact i think its only on cars 97 and up.
This post has been edited by lagos: Jun 1, 2004 - 6:23 PM
post Jun 1, 2004 - 6:30 PM
LatinKraze
Joined Oct 22, '03
OBD II only
post Jun 1, 2004 - 7:05 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
OBD II = 96+
Team 6gc 2005
post Jun 1, 2004 - 7:10 PM
macavely
Joined Nov 4, '02
DG we have the OBD-I and that is in the center dash.. its those 2 plugs that are just hang around doing nothing
post Jun 1, 2004 - 8:56 PM
shid
Joined Jan 8, '04
From LA
yeah, I was wondering if it would work on a swap. THe OBDII info listed here is correct. I actually use the OBDII plug above the gas pedal to connect to my laptop and do cool things like DECENT, ACCURATE 0-60 and quater mile times. It's tight stuff.
But, doesn't the OBDII just get it's info from the ECU? and since the swap stuff is still connected to the ECU.. I might not be right tho
post Jun 1, 2004 - 10:17 PM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
If i wired all the wires up right then the diagnostics would still work if i had a swap or not but my thing is i cant find the connector if there is even one one the car!
there should be only one connector not two???? where exactly are these 2 plugs you are talking about macaveli? i never noticed em.....
i got nothing above the gas pedal.
remember i got the 95 gt which is obd1 but older cars have this connector so i figured the celi might have it too.
thanks,
dg
post Jun 1, 2004 - 11:11 PM
shid
Joined Jan 8, '04
From LA
OBDI is a lot older format- less computer friendly- I dont believe they even make easy conputer hookups for it.. the general consensus is that if you have OBDI, you're screwed
i always thought that the diagnosis boxes only work on 96+ cars. if your motor is from a 90 alltrac, then you have to jump the diagnosis box and count how many times your check engine light flashes.
This post has been edited by lagos: Jun 1, 2004 - 11:15 PM
Lo-Fi Version Time is now: August 26th, 2026 - 8:09 PM
