> Swap Wiring Info
post May 31, 2004 - 12:02 AM
in an effort to help clear up the mystery about wring for the swap, i decided to start this thread. i plan to post any info that i find during my reaserch and would like to see the rest of you do the same. this way we can all share information and make swaping less of a hassle for future generations.
to start off, here are some ECU pin outs from my 91 BGB. i dont have any 6th gen pinouts yet but ill scan them in when i get my hands on a 6th gen BGB.
correct me if im wrong, but ECT means automatic and no ECT means manual?
- lagos   Swap Wiring Info   May 31, 2004 - 12:02 AM
- - lagos   From the Haynes 86-99 manual:   May 31, 2004 - 12:30 AM
- - lagos   3sgte pinouts from the 91 BGB:   May 31, 2004 - 12:36 AM
- - Doge   Does anyone have ANY info on what is required in o...   Jun 1, 2004 - 8:50 PM
- - lagos   what i would like to know, is if you HAVE to rewir...   Jun 1, 2004 - 9:11 PM
- - Coomer   Tim and I removed the information regarding the sh...   Jun 2, 2004 - 4:59 PM
- - Doge   Coomer I hope you realize that you just erased alo...   Jun 2, 2004 - 5:04 PM
- - Coomer   Good point...DG's information is now below...s...   Jun 2, 2004 - 5:12 PM
- - Doge   Thank you Coomer   Jun 2, 2004 - 5:14 PM
- - jgreening   Here is my $.02. A Wiring diagram is more li...   Jun 2, 2004 - 5:53 PM
- - lagos   umm... i must have missed out on alot today cause ...   Jun 2, 2004 - 9:56 PM
- - defgeph   I care lagos give that wire hell ..... good luck   Jun 2, 2004 - 10:05 PM
- - DG_Performance   Wow everything i posted b4 has been chopped up ???...   Jun 2, 2004 - 10:54 PM
- - DG_Performance   So just to clear things up now since whoever delet...   Jun 2, 2004 - 11:05 PM
- - Coomer   Yeah, we're not blaming anyone. No-one did any...   Jun 2, 2004 - 11:55 PM
- - lagos   Coomer, the way i see it is that information is fr...   Jun 3, 2004 - 12:12 AM
- - sinner96ST   i read in another thread that mike isn't going...   Jun 3, 2004 - 12:14 AM
- - lagos   QUOTE (sinner96ST @ Jun 2, 2004 - 10:14 PM) i read...   Jun 3, 2004 - 12:17 AM
- - macavely   i'm not sure what mike did cause i never seen ...   Jun 3, 2004 - 12:25 AM
- - Doge   What Coomer deleted wasn't anything that would...   Jun 3, 2004 - 12:41 AM
- - presure2   commer & tim: why was my post deleted? i didn...   Jun 4, 2004 - 7:23 AM
- - macavely   QUOTE (presure2 @ Jun 4, 2004 - 7:23 AM) commer ...   Jun 4, 2004 - 7:25 AM
- - lagos   i think the problem is that one guy figured it out...   Jun 4, 2004 - 8:06 AM
- - Doge   I know for sure that I'm going to post as much...   Jun 4, 2004 - 4:25 PM
- - Digndoug   Man, after readoin this.. Thsi sight has just gott...   Jun 4, 2004 - 4:49 PM
- - Doge   I know we're pretty much being forced to reinv...   Jun 4, 2004 - 4:57 PM
- - Coomer   You guys have to understand that I'm not tryin...   Jun 5, 2004 - 12:27 PM
- - Drocay   coomer i've been wondering is Mikes info truel...   Jun 5, 2004 - 12:38 PM
- - Doge   QUOTE (Drocay @ Jun 5, 2004 - 10:38 AM) coomer i...   Jun 5, 2004 - 12:50 PM
- - macavely   QUOTE (Drocay @ Jun 5, 2004 - 12:38 PM) coomer i...   Jun 6, 2004 - 11:29 AM
- - Coomer   I don't know about printed works, but I know t...   Jun 6, 2004 - 12:50 PM
- - lagos   lets get back on topic.... wiring update. today t...   Jun 6, 2004 - 8:13 PM
- - Silver94CelicaOwner   QUOTE (lagos @ Jun 4, 2004 - 6:06 AM)i think ...   Jun 6, 2004 - 8:33 PM
- - shid   Even if Mike's copywrite was valid, it might n...   Jun 6, 2004 - 8:54 PM
- - Rjb23   Keep this thread going lagos, it will come in hand...   Jun 6, 2004 - 9:06 PM
- - lagos   QUOTE (Rjb23 @ Jun 6, 2004 - 7:06 PM) Keep th...   Jun 6, 2004 - 10:06 PM
- - defgeph   Is there a difference in the wiring harness from s...   Jun 6, 2004 - 11:13 PM
- - macavely   from what i have found the harness is the same for...   Jun 6, 2004 - 11:21 PM
- - FAQdaWorld   I really doubt Mike can hold a copyright patent or...   Jun 7, 2004 - 12:44 AM
- - Doge   Immediately after Mike sent me that response askin...   Jun 7, 2004 - 1:54 AM
- - lagos   QUOTE (Doge @ Jun 6, 2004 - 11:54 PM) Immediately ...   Jun 7, 2004 - 8:32 AM
- - shid   More of us know about copywrite law than we know a...   Jun 7, 2004 - 11:15 AM
- - defgeph   QUOTE (lagos @ Jun 7, 2004 - 8:32 AM) wiring for t...   Jun 7, 2004 - 4:56 PM
- - lagos   QUOTE (defgeph @ Jun 7, 2004 - 2:56 PM) QUOTE (lag...   Jun 7, 2004 - 10:27 PM
- - defgeph   Ok, I went to and got as haynes manual for no reas...   Jun 8, 2004 - 3:04 PM
- - shid   Hayes manuals aren't that great.. for instance...   Jun 8, 2004 - 3:08 PM
- - defgeph   yeah I noticed that .. but we are working with a 5...   Jun 8, 2004 - 3:09 PM
- - lagos   believe it or not, some of the wiring diagrams tha...   Jun 8, 2004 - 11:14 PM
- - macavely   QUOTE (lagos @ Jun 8, 2004 - 11:14 PM) believe it ...   Jun 8, 2004 - 11:35 PM
- - Rjb23   If you had an ST would it be easier to get a GT wi...   Jun 10, 2004 - 4:46 PM
- - defgeph   QUOTE (Rjb23 @ Jun 10, 2004 - 4:46 PM) If you...   Jun 10, 2004 - 5:30 PM
- - lagos   you know, you can just drill a new hole in your fi...   Jun 10, 2004 - 9:02 PM
- - lagos   after talking out my engine, harness and ECU, thes...   Jun 10, 2004 - 9:10 PM
- - Doge   so even if you drilled a hole in the firewall, wou...   Jun 10, 2004 - 9:26 PM
- - CELICAKIDD324   I see everyones view in this post, However Mike bu...   Jun 19, 2004 - 10:05 PM
- - lagos   3sgte fuse box 5sfe fuse box ...splits into 2 ...   Jun 19, 2004 - 11:17 PM
- - CELICAKIDD324   one more add in to my last post, assume every one ...   Jun 20, 2004 - 12:16 AM
- - CELICAKIDD324   thankyou all for any help you have given, i have f...   Jun 20, 2004 - 11:04 PM
- - lagos   thats great news. i wish my car ran. only thing le...   Jun 20, 2004 - 11:29 PM
- - Doge   There is no diagram that has those wires labled fo...   Jun 21, 2004 - 12:29 AM
- - doGGy   Some one, get the wiring done my mike, and take a ...   Jun 21, 2004 - 8:26 AM
- - Drocay   prob is everyone who could do that wont.   Jun 21, 2004 - 11:27 AM
- - CELICAKIDD324   If i knew it would have helped i would have taken ...   Jun 21, 2004 - 6:23 PM
- - Digndoug   i would say, any pics or info you have would help ...   Jun 22, 2004 - 12:47 AM
- - Drocay   THIS WAS ALL POSTED BY OUTSIDER ON CELICA.NET Ex...   Jun 22, 2004 - 11:30 AM
- - Outsider   (click on pictures for full size) Excel file li...   Jun 22, 2004 - 7:01 PM
- - 95BlueGT   i have the 5sf3 engine wiring layout saved on my c...   Jun 23, 2004 - 3:41 PM
- - Rjb23   Any news on this?   Jun 27, 2004 - 11:55 PM
- - reborn0323   anyone have the wiring info for 7afe to 3sgte???   Jun 28, 2004 - 4:24 AM
- - lantz2121   does anyone know how to get a hold of qatar11 (mik...   Jun 29, 2004 - 11:44 PM
- - Jabberwock   I have a 7AFE to 3SGTE wiring Diagram...hehe   Jun 30, 2004 - 1:34 AM
- - Rjb23   Post it.   Jun 30, 2004 - 5:33 AM
- - Outsider   Mike (qatar11) has placed this notice on his webs...   Jun 30, 2004 - 6:27 AM
- - playr158   doesn't this mean that yall can post pics of d...   Jun 30, 2004 - 8:55 AM
- - Doge   Yeah! I'm with playr! Nobody can buy...   Jun 30, 2004 - 12:31 PM
- - Andason   All someone has to do to avoid plagurism (copyrigh...   Jul 1, 2004 - 6:55 PM
- - Jabberwock   I would post what mike gave me, but I paid a butt ...   Jul 1, 2004 - 8:31 PM
- - lagos   as it stands right now, there is pretty much all t...   Jul 1, 2004 - 10:26 PM
- - defgeph   QUOTE (lagos @ Jul 1, 2004 - 10:26 PM) as it stand...   Jul 1, 2004 - 10:28 PM
- - Rjb23   Hey here is a site that I found that might help ou...   Jul 2, 2004 - 6:36 PM
- - Drocay   defgeph Posted on Jul 1, 2004 - 10:28 PM QU...   Jul 2, 2004 - 7:22 PM
- - moltar   Hopefully by the time I do my swap next summer thi...   Jul 2, 2004 - 11:43 PM
- - rsos1   Ok so it looks like the fuse box is taken care of ...   Jul 3, 2004 - 4:54 PM
- - Rjb23   All this info needs to be stickied when it is done...   Jul 3, 2004 - 7:10 PM
- - Outsider   The EA-1 fuse box diagrams that I posted are for t...   Jul 3, 2004 - 7:32 PM
- - DG_Performance   Where are these EA1 diagrams posted? I would like...   Jul 4, 2004 - 11:31 AM
- - lagos   EA-1 Pinouts   Jul 4, 2004 - 11:42 AM
- - DG_Performance   Also, I just had to help a "former qatar harn...   Jul 4, 2004 - 11:50 AM
- - lagos   DG_Performance, would you be interested in helpi...   Jul 4, 2004 - 11:55 AM
- - DG_Performance   Sounds like a good idea to me, we should get toget...   Jul 4, 2004 - 12:04 PM
- - sinner96ST   hey, i like this thread.. so bump for more wiring ...   Jul 4, 2004 - 12:20 PM
- - lagos   this is one small step for man...and one giant lea...   Jul 4, 2004 - 12:54 PM
- - Outsider   DG_Performance The link is to info stored on m...   Jul 4, 2004 - 1:00 PM
- - DG_Performance   I looked at that exel file and i dont think that a...   Jul 7, 2004 - 9:28 PM
- - lagos   DG, whats not the same about it? i gave it a quick...   Jul 8, 2004 - 7:44 PM
- - DG_Performance   the good thing is that all the colors are right ba...   Jul 11, 2004 - 4:44 PM
- - jgreening   I am not sure if this is a repost but I came acros...   Jul 14, 2004 - 9:11 PM
- - funnys_tears   hello there, i has the st model i was just make ...   Apr 27, 2005 - 2:13 PM
- - lagos   holy blast from the past ! you have to fully ...   Apr 27, 2005 - 2:43 PM
- - jayi12-15psi   I'm just gonna bump this, cause its got alot o...   May 5, 2005 - 12:39 PM
Lo-Fi Version Time is now: June 23rd, 2026 - 5:06 PM
