Jun 3, 2004 - 2:53 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '02 From Baltimore, MD Currently Offline Reputation: 1 (100%) |
Ok so brian and me changed my oil today.... read the convo and help me out please!!!!!
NunCHUCKSNinja: my car vibrates a lot now NunCHUCKSNinja: and acts weird Sortafamous: what do you mean? NunCHUCKSNinja: when i accelerate it vibrates and when i was at idle it was changing rpm Sortafamous: hmm Sortafamous: it was 10w30 right? NunCHUCKSNinja: yep NunCHUCKSNinja: i think the vibration might be partly because the muffler was bent and now it hits the back bumper NunCHUCKSNinja: and also it lags a little bit when i accelerate Sortafamous: im lookin around Sortafamous: but i dunno Sortafamous: it might be that stop smoke stuff Sortafamous: cause its so thick I was lazy so I didnt feel like typing the whole situation so that convo sums it up. -------------------- ![]() |
Jun 3, 2004 - 3:13 PM
The answer is b.
Jun 3, 2004 - 3:15 PM
That helps man
could somebody give me a good answer? -------------------- ![]() |
Jun 3, 2004 - 3:21 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
he has an intake and has had one for a while
Jun 3, 2004 - 3:26 PM
If there is thick smoke coming out, I bet he blew an oil ring. If thats the case, your car is worthless I believe.
Jun 3, 2004 - 3:42 PM
there is no smoke coming out, just the problems he posted in our convo
Jun 3, 2004 - 3:51 PM
Yeah ive had the injen short ram intake for over a year. I get my oil changed at tires plus every time this is the first time I have changed it myself. So im not sure what oil they use, but most likley it would be 10w30 wouldnt it?
Jun 3, 2004 - 3:58 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 26, '03 From Wisconsin Currently Offline Reputation: 0 (0%) |
wow the celica is such an easy car to change the oil on. you should be slapped for ****ing that up some how
-------------------- i am awesome
Jun 3, 2004 - 4:09 PM
how could i **** it up when i mightve just put a different oil in the car than the car is used to. we did everything right. you should be slapped in the face for being such a jackass
Jun 3, 2004 - 4:19 PM
So what should I do if thats the case?
Jun 3, 2004 - 5:38 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 22, '04 From illinois Currently Offline Reputation: 0 (0%) |
sounds like he went from a senfetic (spelling-sorry) oil to a regular everyday oil, and he isn't use to it, or the engine really really didn't like it. Before i switch over to senfetic, my car idled a little bit harder. I go with pure, i love it, and i can feel the difference.
-------------------- ![]() The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
Jun 3, 2004 - 6:56 PM
Enthusiast ![]() ![]() ![]() Joined Apr 10, '03 From South Central Los Angeles Currently Offline Reputation: 0 (0%) |
On the original post, you mentioned the following.
Sortafamous: it might be that stop smoke stuff Sortafamous: cause its so thick Now, as far as I know, stop smoke is some kind of additive that you add to your car when there is too much smoke coming out of your exhaust. If this is the case and your car was already realeasing smoke, then something inside must be messed up. If that's the case, you have to determine what color the smoke was, and then you'll find your problem. just my $.02 |
Jun 3, 2004 - 7:23 PM
Enthusiast ![]() Joined Dec 2, '03 From Virginia Currently Offline Reputation: 0 (0%) |
You may want to look here it talks about how additives can be detrimental to the performance of your engine. I doubt you blew anything up just changing the oil, but if you are using a new oil with an additive you may want to go back to your old one and see if that fixes the problem.
Jun 3, 2004 - 9:07 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
I tend to think that its not your oil thats causing these problems....the 5S-FE is meant to use 10w-30 so that shouldnt be an issue. First check just to make sure that no oil is leaking from either the oil pan bolt you took off or the oil cap on the valve cover. Also if you slopped any oil onto the engine in the process of changing it, it can smoke a bit and smell bad like you're runing your engine too hot.
After your sure both are tight and theres enough oil in the engine (or too much for that matter) and it still makes these obnoxious quirks, get it checked out by a reputable shop. Its not worth it to guess, and the description of the problem is so brief that i honestly dont know what else to recommend. Sometimes a simple tune up can do wonders...mine runs much smoother than it did before i got mine, so look into it if its really bad. Besides, answers like "check your intake" or "your engine is already dead, sorry." arent really the best thing to go by anyway. EDIT- Our cars tend to vibrate a little under acceleration sometimes...i get this occasionally when im accelerating onto a highway and other people have encountered the same thing. I think it has to do with the small engine under load when climbing a hill or pushing it hard in a high gear. So dont worry to much, its normal. This post has been edited by Silver94CelicaOwner: Jun 3, 2004 - 9:14 PM -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Jun 4, 2004 - 2:46 AM
Enthusiast ![]() ![]() Joined Jun 21, '03 From FRANKFORT,KENTUCKY Currently Offline Reputation: 0 (0%) |
Sortafamous: cause its so thick Are you saying that you may have,by accident, used stop smoke instead of oil? |
Jun 4, 2004 - 3:07 AM
where is the last place you got gas from.. and did you change from one oct/ to another? -------------------- |
Jun 4, 2004 - 10:55 AM
no we put that in there to help the valve seals, still used 4 quarts of oil |
| Lo-Fi Version | Time is now: July 12th, 2026 - 4:58 AM |
