Feb 18, 2003 - 1:59 AM
![]() Enthusiast ![]() ![]() Joined Feb 11, '03 From Phila, PA Currently Offline Reputation: 0 (0%) |
Could someone help me out here? I got a Greddy SP cat back exhaust for my '97 ST. I haven't put it on yet because I got it Friday and I was about to rip off my stock exhaust when I noticed that there is an 02 sensor after the Cat but before the rear axle. If you look at my profile picture the sensor will have to go in customly on the really long straight pipe right after that thicker cylinder peice(whatever that is called)(not the pipe with muffler, the other). I didn't know if I would need a special part to weld in so the sensor could screw into the exhaust (because it screws into a nipple fixture)which is welded into the exhaust(but not pre drilled for the Greddy). Most parts places were closed so I didn't try it for fear of being stuck with a non running car(or illegal). Whats the deal with the sensor im describing? I guess it's so the ECU knows what the emissions are like after the exhaust gases go through the cat but I thought that was registered in the header pipping. I hope this doesn't cause a problem if I get higher flow cat and the sensor reads a dirtier exhaust measurement and cuts the fuel back. Do I need this sensor or is it bull$hit? Luckily my father's shop has a pit I can drive my car over to work underneath the car which is how i noticed the sensor. Do I have to cut a hole in my pretty new exhaust and weld in this O2 sensor or can I just be a rebel and not put it in? It pissed me off so much cause I wanted to bolt that bastard up so bad and hear that throaty sound that its supposed to make. Hopefully those of you that have this exhaust can let me know what you did. Nothing good is ever easy!
This post has been edited by Milds3vn: Feb 18, 2003 - 10:12 AM |
Milds3vn Greddy Cat Back Exhaust Feb 18, 2003 - 1:59 AM
Blackcelliman I have the same problem that you do. I have an st... Feb 18, 2003 - 3:11 AM
Milds3vn Nevermind I got it installed and cut a hole in the... Feb 20, 2003 - 12:50 AM
3TST I checked under my car at the weekend and it appea... Feb 24, 2003 - 5:20 AM
Matthew we like clean air Feb 24, 2003 - 11:34 AM
96cel_John i just got my greddy sp today.
so uh...is it bad ... Mar 5, 2003 - 10:05 PM
FallenHero Yes, your car will be all like,,, "WTF?... Mar 6, 2003 - 12:22 AM
96cel_John im at school now...if i take it to meineke, can th... Mar 6, 2003 - 10:53 AM
Milds3vn Yea they should know how to install everything. Mar 6, 2003 - 3:54 PM
Neipas09 Yea meineke should know how to install it, and if ... Mar 6, 2003 - 6:37 PM![]() ![]() |
| Lo-Fi Version | Time is now: May 20th, 2026 - 8:52 AM |
