> How to blow up your engine, Interesting site for the 3s swappers
post Jun 4, 2004 - 5:03 PM
Doge
Joined Dec 2, '02
From Portland, Oregon
Thought I would share this so people can kind of get an idea on what makes these things go BOOM!
BOOM BOOM!
post Jun 4, 2004 - 5:25 PM
sinner96ST
Joined May 15, '03
From Aurora IL
QUOTE (Doge @ Jun 4, 2004 - 3:03 PM)
BOOM BOOM!
i see tons of rod bearing problems...
post Jun 4, 2004 - 5:35 PM
Doge
Joined Dec 2, '02
Seems like alot of them say 12psi boost is the max "safe" amount of boost. Which is interesting because I've always been told 15psi. Good little bit of info to know i guess.
post Jun 4, 2004 - 8:50 PM
Jabberwock
Joined Sep 22, '03
Well, if you think about it, TOYOTA made a reason to put the boost cut at 12 psi.
post Jun 6, 2004 - 6:27 PM
obi1kinob
Joined Mar 1, '04
From Sacramento, California
Yeah so many oil/rod bearing problems. Kind of scary...
post Jun 6, 2004 - 7:06 PM
Doge
Joined Dec 2, '02
Kinda makes you want to go check your oil level doesn't it? =) These people learned the hard way, just like me. I didn't check my oil on my 5sfe after it was 3,500 miles since the last oil change. For some reason the 5s didn't like nasty oil so it found a way to get rid of it without me knowing. Rod bearing started going out. Luckily I stopped the car the instant I heard a noise so nothing too major happened. It just knocks between 2k and 3k rpm...anything over or under that and it doesnt make a noise. But I dont drive it anymore as I want to see exactly what that little bit of knocking did to my rod bearing. I should hopefully find out within a few weeks cause the 5s is getting replaced with a 3s.
post Jun 6, 2004 - 8:26 PM
Magic
Joined Mar 30, '03
From Cyprus
post Jun 6, 2004 - 10:14 PM
celicaracer18
Joined May 23, '04
From Meridian, MS
QUOTE (Doge @ Jun 7, 2004 - 12:06 AM)
exact same thing happend to my 7afe
and why i hava a 3 on the way
i also have crower pro billet rods, wiesco coated pistons(may get different ones, i'm open to suggestions, it cam with a kit for a great price), high performance bearings, ferra valves, and i still have to order the hks valve springs and either hks or apexi HG (apexi is cheaper don't know which is better)
post Jun 7, 2004 - 2:53 AM
KAMiX
Joined Mar 4, '03
Haha I blew an old landcruiser 4x4 when I was 16 from no oil, and I have religiously checked my oil & battery ever since.
I don't like that link. That web page is just depressing. All those 3s' gone to waste frown.gif
post Jun 7, 2004 - 3:19 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (KAMiX @ Jun 7, 2004 - 7:53 AM)
I've blown up many engines... I mean... many. 2 13B rotaries (last serious racecar), 2 4AGEs (one bigport one smallport, one in an AE86 one in an AE92), 1 7AFE (race-prepped in my previous Celica which is now a little ball of steel) , 1 3SFE (Camry parts car at our shop), 1 5SFE (my cousin's Camry before swap), 1 3SGE (bad head gasket problems on these 1 gens w/ TVIS), 1 22R (my dad's beat-up truck), 1 22RE (my 4Runner before the turbo), 1 22RTE (my 4Runner with the turbo), 1 4AC (my dad's beat-up rolla), 1 D16 (my green EK hatch), and 1 B18 (my cousin's Teg). Working on cars and racing them has its kicks. ;P
post Jun 8, 2004 - 8:38 PM
KAMiX
Joined Mar 4, '03
Thats a good achievement but you sound like you are proud kwanz. ?? biggrin.gif
The 13B's are nice.. An old friend of mine had a couple of old Rx7's with 13b's. He also had a 7 with a 20B turbo monster ported.... that thing was mad. Also a friend has a AE86 with exhaust/intake/mild internals & new ecu/management system. Those little things fly biggrin.gif
This post has been edited by KAMiX: Jun 9, 2004 - 6:43 AM
post Jun 9, 2004 - 12:31 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (KAMiX @ Jun 9, 2004 - 1:38 AM)
I'm proud of every other engine aside from the 13Bs. Both were relatively recent rebuilds and both had seals that failed. I though long about keeping the FC and doing a 3 rotor or even 4 rotor build... but then I started racing my Celica and noticed my solo times weren't all that different between the two... so I just concentrated on my race Celica at the time (not this current one)... unfortunately, the Celica's motor, after it's modifications became an intereference motor and blew up after a a couple of combined mishaps. Engines themselves, are pretty tough when taken care of...
Lo-Fi Version Time is now: August 27th, 2026 - 7:07 AM
