Jun 10, 2004 - 9:35 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) |
which color wire do I have to splice into on the air/fuel sensor for the 5sfe??
Thanks NEVERSTOP -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
Jun 10, 2004 - 10:07 PM
The wire from your O2 Sensor below the Header. On my ST, they were both gray, we hooked up the power and ground then tapped both till 1 of the 2 worked. -shrug
Jun 11, 2004 - 9:53 PM
![]() Enthusiast ![]() ![]() ![]() Joined May 23, '04 From Meridian, MS Currently Offline Reputation: 2 (100%) |
does anyone know the answer to this for a mr2 3sgte
Jun 11, 2004 - 10:00 PM
I ended up hooking it up to the air/fuel sensor, I spliced into the black wire with the red strip ( I think... will have to double check) and that seems to work fine.. will find out for sure tomorrow which wire it is
Jun 11, 2004 - 11:55 PM
A/F meter is not a good way to judge ur mixture, not w/o wideband...it really only tells u ur o2 sensor is working.
This post has been edited by Supersprynt: Jun 11, 2004 - 11:55 PM -------------------- |
Jun 12, 2004 - 9:35 AM
It's been giving me a pretty acurate reading.. right where I would expect the mixture to be for the 5sfe and the specific rpms... its mostly for show on the 99 so im not overly conconcerned newayz but it seems to be working fine wired into the a/f sensor edit: where you talking about using the a/f sensor or the a/f guage??? LOL might of misread your post This post has been edited by NEVERSTOP: Jun 12, 2004 - 9:37 AM -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
Jun 13, 2004 - 11:53 AM
Enthusiast ![]() ![]() Joined May 1, '03 From Houston , Texas Currently Offline Reputation: 4 (100%) |
I have the same question for the ST I have a air fuel gauge. I just tried to install it but the only way I can get it to work is by unpulgging the sensor to the ecu. I know I did this wrong help me out guys.
| Lo-Fi Version | Time is now: September 1st, 2026 - 2:51 AM |
