Feb 19, 2003 - 3:24 AM
Z-glide style front and sides skirts does any one have them and how do they fit. I need to know befor i go and buy them.
Feb 19, 2003 - 3:34 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 12, '02 From New Jersey Currently Offline Reputation: 0 (0%) |
the z glide is one of my favorites...i want the zephyr back..its so plain, simple and looks so good..i can just picture my Apex'i N1 muffler poking out the back..would look so good
Feb 19, 2003 - 12:03 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 9, '03 From St. Louis Currently Offline Reputation: 0 (0%) |
the fitment below the turn signals was a little rough, but not enough to complain about, if you buy from erebuni the holes are not pre drilled, not that thats a big deal. What I did was line my stock bumper with rubber weather stripping, and fit the bumper with two bolts on each side where the lip wraps around the wheel well. Then I drilled holes in the top of the z lip and used zip ties to pull it as close as I could to the bumper and put two more bolts on top. Hope this helps-
also get some koni adjustables or something to lower it on some bigger wheels, on a stock suspension the lip scrapes everywhere. on the bottom of the lip(since its fiberglass) use some rubber weather stripping to cover the underside of the lip, no matter how hard you try, you will scrape so you better protect it from cracks starting on the bottom. And beware the curb and those concrete parking blocks in parking spaces. often those are to high to clear with the lip.(it only sits like 5 1/2" off the ground. whereas the invader sits about 7") hope this helps you out, good luck with the kit. -------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
Feb 19, 2003 - 6:16 PM
yea man thank that does help
Feb 19, 2003 - 9:51 PM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 30, '02 From Franklin,Tn Currently Offline Reputation: 0 (0%) |
Hey Mac I got them sittin in my garage. The front fits really good, its only gona need a little modification to make it fit. As for the side skirts, the over all fit is good, however the tops of the sides are the only fitment problems. But any good shop will be able to correct it.
Bryan |
Feb 20, 2003 - 2:32 AM
yea i'm planning on buy the kit right befor i get my car painted and the dents taken out. and my girls saw a the Z Glide kit and she loves it so that made me want to get it even more.
| Lo-Fi Version | Time is now: August 1st, 2026 - 9:02 AM |
