Feb 19, 2003 - 5:07 AM
Enthusiast ![]() ![]() Joined Jan 9, '03 From Concord, NC Currently Offline Reputation: 0 (0%) |
Anyone know of a 6spd 6th gen, or know if it is possible with any toyota non 6spd tranny?
Feb 19, 2003 - 6:29 PM
Enthusiast ![]() ![]() ![]() Joined Oct 1, '02 From North Bethesda, MD Currently Offline Reputation: 0 (0%) |
if you have an ST, you coule use the 6spd from an AE111 Levin.
BUT you don't want to. the transmissions are set up for the engines they are connected to. a 6spd will give you no advantages, and actually will really screw up the way the engine responds. it will, in my opinion, detract from the performance and driveability of the car. the 7afe has decently short gear ratios... 6 spds are really meant for engines with really tall gears, so highway cruising speed will not be at like 8K RPMs. -------------------- 1994 Lexus ES300
1989 Supra Turbo 1990 RHD ST185RC - JDM Spec |
Feb 19, 2003 - 10:22 PM
thanks for the words of wisdom, so I guess its about the same for a GT.
Feb 19, 2003 - 10:52 PM
Charlie, are all of the AE111 manual trannies six speed, or is it just some of them?
Feb 19, 2003 - 11:24 PM
Enthusiast ![]() ![]() ![]() Joined Oct 27, '02 From Barbados Currently Offline Reputation: 0 (0%) |
Nope.
You have autos. The old lev. have 5 speed. The 1997 - 98 and up have 6 speed. AE111 comes with auto or 6sp with black top 4AGE 20v w/ VVT-i. There are beautiful cars. Honda wippers We have guys down here with 20v 4AGE Silver Tops with Black Tops computers installed properly tuned beating the hell out of Hondas here. There are 2 Honda Civic Type R's here which are holding some lashes from the silver and black tops 4age 20v. This post has been edited by west_minist: Feb 19, 2003 - 11:28 PM -------------------- West_Minist
Hydra EMS Dealer & Tuner Subaru ECUFlash Tuner http://www.socob.bb http://xtremeracingtuning.com Viciously Tuned, Driven Hard ![]() |
Feb 19, 2003 - 11:34 PM
You should recruit them to the site, so they can give us some more info on exactly what they've done and everything. Thanks for the quick reply by the way. -------------------- New Toyota project coming soon...
Feb 20, 2003 - 12:15 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
I have heard a black top clip is really hard to find. Now I know why. (97-98)
Also, how much more power does the black top have? |
Feb 20, 2003 - 12:37 AM
actually, that's not even the half of it. the AE111 had the blacktop 20V 4age which was rated at 165 HP. this car is very rare. on this rare car, the 6spd tranny was an OPTION. -------------------- 1994 Lexus ES300
Feb 20, 2003 - 1:29 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 12, '02 From New Jersey Currently Offline Reputation: 0 (0%) |
god how i would love one of them..
Feb 20, 2003 - 9:38 AM
Black top was available from 96 and up. There are many AE111. There are the BZ Carib Wagon, BZ Touring wagon, Carina GT and the Levin(late 96 and up) This post has been edited by west_minist: Feb 20, 2003 - 10:20 AM -------------------- West_Minist
Feb 20, 2003 - 10:18 AM
These guys are very busy. My mechanic is one and the other is not really internet friendly. But yours truely is here if you believe me, which to some point you don't. Mainly these guys starts of with cars under 1100Kg with non 5AFE engines. For instant, my mechanic had a 1997 4AFE Corolla in his car. 1080Kg Like all the rest and only a few, and I said a few, have swap in a 4AGE 20 silver. 1) A filter was put on and a 2" pipe ran from the engine to the muffler like HKS, Magnaflow(which I have on my subaru). CAT and Resonator was taken out. Some have cats in. 2) Racing plugs, msd digital 6 plus are install. Some have left in the oem coils. One is going to change his coil to a Nologu M80. But I recommend to him to use the M75 since the Digital 6 cannot really pust that coil. The Crane Cmans Hi6 can. 3) Adjustable Fuel pressure regulator with A/f, temp, fuel pressure gauges are install. 4) Tuning extensively. 5) At this point the car gets on like a standard black top and more. 6) At this point, these cars are leaving black tops and giving honda's the tail except thge type R. 7) A black top ECU is swap in and engine properly tune. Electrical work have to be done if harness is not available. But not much work. Also the AFM will have to be replace with a MAP sensor. 8) The car idles between 500 - 1500 rmp during learning mode. Sometime over 1000rpm is fairly common, but this can be sorted out with throttle sensor and idle screw on the right side of engine just below the intake box. 8) More tuning. 9) By now, you now giving the type R 3+ car lengths. 10) Next step involves cutting the throttle bodies in the throttle body box. This will enble up top performance. 11) You might want to invest in a better filter from Greddy., HKS and others for high flow. Some how, which is normal, the 4AGE 20v likes to be use with out the throttle bodies box. 12) Anything after is more power. New TRD head gasket to increase compression some more, TRD Header or HP Racing, Fuel computer, bigger throttle from companies like twtinduction, nology Hotwires, lightened flywheel, cams, bigger forgew pistons, vavle train upgrades. All of these part can be had from TRD or todaraing.com 13) One and only one, my mechaine have ran a switch to the VVT to have it on all the time. The engine gets on like it have big cams, but the acceleration is like mad. 14) Next step is turbocharging. 15) Drag tires over 205 is needed. 215 and up would produce good traction. Mt turbocharge from scrap write up is a part of what he did. This post has been edited by west_minist: Feb 20, 2003 - 10:02 PM -------------------- West_Minist
| Lo-Fi Version | Time is now: May 25th, 2026 - 2:58 AM |
