Jun 15, 2004 - 12:22 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
I used to have this Corvette. It was sooooo fast, but every other day something went wrong with it. Do you swapers find that to be the case? can you tell the car wasn't meant to have that engine in it? Oil leaks, bad idle, rough starts, other odd problems you might have? I was just curious. I'd also Love to see some time slips and Dyno runs. I was over at Newcelica.org looking at their dyno charts and time slips and was kinda disgusted.
So,I asked. Thanks Jon |
Jun 15, 2004 - 10:35 AM
My car has trouble starting when i havent used it for a day or two. It just needs an extra 5 cranks before it turns over. IDK why? I'm leaking nothing. I think the fact that everythings been changed and custom done is why problems arise. Other stuff just happens and will happen to any car, its 10yrs old, stuffs going to go wrong.
Jun 15, 2004 - 9:44 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jun 21, '03 From Pennsylvania Currently Offline Reputation: 3 (100%) |
My car has trouble starting right up too. If it has not been run for a few days it likes to not start right up. my 5s never did that? after the 3s starts up it idles bad for about 5-6 seconds and then is all good. dont know why thta happens.
other than that i am happy with the big difference it made. and i hope nothing is bad with the engine since i dont know how it was driven b4 i got it. mainly hoping that the engine was not beat on by the previous owner????? dg -------------------- ![]() |
Jun 15, 2004 - 11:44 PM
what starter did you guys end up using? when i installed mine, i had to use the 5sfe one because the 3s starter didnt sit right with the 5sfe tranny.
Jun 15, 2004 - 11:51 PM
Forgive me for hijacking the thread, but how is the swap going Lagos?
Jun 16, 2004 - 12:50 AM
the 3sgte is in my engine bay, but the car is not yet running. still have to connect the crossmembers, axels, suspention, wiring, etc.
Jun 16, 2004 - 7:02 AM
keep us updated....and continued good luck
Jun 16, 2004 - 8:15 AM
I am pretty sure im using the 3s starter, seemed to sit fine.
Jun 16, 2004 - 12:50 PM
Enthusiast ![]() ![]() Joined Dec 21, '02 From Orlando Currently Offline Reputation: 0 (0%) |
I never have problems starting mine. 3S motor is fun stuff. The pain in the ass is the 3-4 months following the swap when everything has to be replaced. Glad that's over with!
Jun 16, 2004 - 12:53 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
are any of you 3s guys using ur cars as daily drivers ?
-------------------- ![]() I will return one day. |
Jun 16, 2004 - 12:56 PM
Again, that would be me.
Jun 16, 2004 - 1:02 PM
Enthusiast ![]() ![]() ![]() Joined Apr 10, '03 From South Central Los Angeles Currently Offline Reputation: 0 (0%) |
1. I'm extremely happy with my car.
2. No major problems, just lil things that are fixes in 1-2 hours max. 3. My car is a daily driver. |
Jun 16, 2004 - 7:07 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
I don't have a swap but I'll reply anyway. My Celica starts with only one turn..even after I turbocharged it. My fast Supra takes a while to start. So I think that just my modding a car it'll freakin' start acting up...it's just Murphy's law.
Jun 16, 2004 - 11:33 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 25, '02 From Pittsburgh/Clairton, PA Currently Offline Reputation: 1 (100%) |
just buy yourself a Jeep Charoke(sp)...
Jun 16, 2004 - 11:54 PM
actually I'm thinking 00GTS these days... and what all goes wrong in the first few months? alternator, belts, etc?
Jun 17, 2004 - 2:49 AM
Enthusiast ![]() ![]() ![]() Joined May 15, '03 From Aurora IL Currently Offline Reputation: 0 (0%) |
lift bolts. if you buy one, have them inspected immediately. i remember there being a TSB about this a while ago. |
Jun 17, 2004 - 8:45 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
He is talking about with the 3sgte swap I believe. |
Jun 18, 2004 - 1:08 AM
with the 3s swap ...anything and everything can break...the best part is that it will probably be your own fault.
Jun 18, 2004 - 9:34 PM
well, I'd have it installed were I to do it. It just seems like something you do to your weekend car.
Jun 18, 2004 - 11:57 PM
ill tell you this....when you are doing the swap, you feel like you are raping your car. every little part of it has to come out. every screw, hose, axel, brake, crossmember, suspention, etc. its a lot of work especially if you have never done a swap before.
it will be all worth it when the car is back on the road....but if i had to do it all over again a 2nd time...i would probably just choose to buy a factory trubo car. -------------------- 15PSI - 30MPG - Megasquirt Tuned
| Lo-Fi Version | Time is now: August 31st, 2026 - 1:23 AM |
