Feb 19, 2003 - 4:03 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) |
this morning i was dropping my sister off at school and on my way home the bass just disappeared! i thought maybe the ground wire was disconnected (as it frequently is) but it was well connected. in fact, everything else was connected properly as well. i dunno whats wrong
This post has been edited by forkee: Feb 20, 2003 - 2:19 AM -------------------- ![]() |
Feb 19, 2003 - 5:17 PM
Enthusiast ![]() ![]() Joined Oct 24, '02 From pennsylvania Currently Offline Reputation: 0 (0%) |
check the wiring inside the box i had this happen to me. i thought i blew the amp but it was just the wires that connect to the sub that were loose
Feb 19, 2003 - 6:35 PM
ok , i looked at both subs, both are still wired to the amp
This post has been edited by forkee: Feb 19, 2003 - 6:36 PM |
Feb 19, 2003 - 7:31 PM
![]() Enthusiast ![]() ![]() Joined Oct 25, '02 From London- England Currently Offline Reputation: 0 (0%) |
Check the simple things first, cable connections, fuses,
ground connections. Is your amp power indicator illuminated? or protection indicator on. If hitting the amp brings back your base intermittently it could be a cracked/ dry solder joint inside the amp, usually caused by a component inside heating and cooling on a regular basis.You may have to open it up and turn the board upside down. Look for any circular cracks around soldered joints. Anything that looks suspicious touch up with a soldering iron to make a solid connection again (do this of course with the power removed from the unit) |
Feb 20, 2003 - 1:43 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 12, '02 From New Jersey Currently Offline Reputation: 0 (0%) |
Check the fuse, i bet thats the problem..do you have a fuse in the line of the wire thats going to the amp from the battery? Thats what my problem was...hopefully that fixes your problem...
that and i dont want u getting a c/f hood and selling ur audio stuff...your car will be faster than mine |
Feb 20, 2003 - 2:18 AM
fuses are ok, both the one on the amp and the one that goes to the battery. ground connections are ok, power light on amp is on, protection indicator light is off. i still dunno what is wrong so i took it out for now, maybe take it apart later. heh, my car is now 80-90 pounds lighter.
Feb 20, 2003 - 2:46 AM
![]() Enthusiast ![]() ![]() Joined Nov 8, '02 From Mongtomery Alabama Currently Offline Reputation: 0 (0%) |
man...that's a lot of weight...what all do you have in there?
| Lo-Fi Version | Time is now: June 10th, 2026 - 11:18 PM |
