Jun 17, 2004 - 10:23 AM
im trying to use the 3sgte AC compressor with my 98 6th gen. the problem im having is that there are 2 AC lines that hook into the comp. the lines from my car are 10mm bolts, but the ones on the 3sgte compressor are 12mm. any tips on how i can make this work?
Jun 17, 2004 - 10:51 AM
you can try making your own lines just got to a hardware store witht he lines.. and have them bend them and put new 12mm on the end of them..
Jun 17, 2004 - 10:53 AM
Enthusiast ![]() ![]() ![]() Joined Apr 10, '03 From South Central Los Angeles Currently Offline Reputation: 0 (0%) |
I'm not exactly sure, but I thought you were supposed to use the GT A/C compressor?
Like I said, i'm not sure, cause I personally took out the AC |
Jun 17, 2004 - 11:18 AM
the gt compressor dosnt bolt up right to the motor. i was thinking of drilling through the 10mm bolt holes to make them 12mm. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jun 17, 2004 - 12:22 PM
Thats what i would personnaly say, just make sure you dont make the walls to thin, cause the slightist bit of trq will crack, an then you would be fugged...
Jun 19, 2004 - 10:33 AM
Enthusiast ![]() Joined Oct 4, '03 From CENTRAL, NY Currently Offline Reputation: 0 (0%) |
I used my gt compressor, fit up ok. You might want to try that again.
-------------------- [img][http://memimage.cardomain.net/member_images/12/web/516000-516999/516799_123_full.jpg/IMG]
| Lo-Fi Version | Time is now: August 27th, 2026 - 2:09 PM |
