Jun 17, 2004 - 2:31 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Feb 17, '04 Currently Offline Reputation: 0 (0%) |
i was doing a lil seach on the forum and wut i noticed was that doing a 3sgte swap into a ST will be a much more difficult and costly swap...mostly because St has diffierent motor mounts and not strong enough tranny,...now considering all that would it be best for me to purchas a Mr2 clip instead since it comes with a stronger tranny
Jun 17, 2004 - 3:27 PM
Either that or get a GT tranny.
Its not that the 7a tranny isnt strong enough, it simply wont bolt up...and yeah its weak also. This post has been edited by Supersprynt: Jun 17, 2004 - 3:28 PM -------------------- |
Jun 17, 2004 - 3:37 PM
so if i get a GT tranny from lets say a junk yard it would come with everything i need for a tranny swap? |
Jun 17, 2004 - 3:40 PM
![]() Enthusiast ![]() ![]() ![]() Joined May 23, '04 From Meridian, MS Currently Offline Reputation: 2 (100%) |
youl need the axels and shift linkage
Jun 17, 2004 - 4:00 PM
Enthusiast ![]() ![]() ![]() Joined Sep 22, '03 Currently Offline Reputation: 0 (0%) |
It won't be much more difficult and costly. More like needing different parts that are basically bolt on. Yeah the motor mounts won't work but getting new ones is sometimes better...so your motor is mounted more strongly.
For the tranny, a lot of swappers had their 5SFE tranny blow or just didn't want to use the weaker tranny and swapped to a camry or MR2 tranny. Therefore I would say the 5SFE can possibly be not strong enough, depending on certain situations. |
Jun 17, 2004 - 4:19 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
Sorry for hijacking but you say mounts I thought it was only the passenger side mount that was different ? you will also need the axle bracket for this swap. DEF -------------------- ![]() I will return one day. |
Jun 17, 2004 - 11:11 PM
ok so lets say without including labor,.... on a ballpark estimate and if i was quoted around 3k to buy and ship a st185 clip to my area how much it would all the materials cost? i have a firend who can do my swap for around $350
| Lo-Fi Version | Time is now: August 31st, 2026 - 5:00 PM |
