> Head Job, what do i do to make this More powerful
post Jun 21, 2004 - 10:43 AM
celicasupra209
Joined Mar 30, '04
From cali
alright i still have questions with the other post but since i dont know the answer to the question in which i have yet.
what do you guys recommend me doing to increase my hp/trq while my engine is dismantle at this point. keep in mind i gotta still meet california smog rules. i heard that i can bore out my block for larger pistons and as long as i dont touch the crans ill be okay with the carb rules, i guess i could look into carb legal crans too. just want to know what kinda of things are i can go to guys
RIP-1995 Toyota Celica GT
Riding a 2002 Honda Civic HB Si
post Jun 22, 2004 - 12:21 AM
KAMiX
Joined Mar 4, '03
If you're not going to put a turbo on there probably don't need stronger pistons but you could up the compression a bit by boring it out. Best bet to start would probably be getting head worked on, polish out all the burrs & increase the port sizes. Maybe get some valve work done like new springs etc. Could get some work done to the throttle body or get a bigger one. Basic breathing mods really.
post Jun 22, 2004 - 12:45 AM
Junior
Joined May 5, '03
From Toronto
QUOTE (KAMiX @ Jun 21, 2004 - 10:21 PM)
a bigger bore won't increase compression.
post Jun 22, 2004 - 2:11 AM
KAMiX
Joined Mar 4, '03
If you get bigger pistons to match it will. Kind of expensive though he's prob better off just getting the head machined &/or new head gasket.
post Jun 22, 2004 - 7:05 AM
Hanyo
Joined Aug 16, '03
From Bay area
increasing the displacement (aka bore/stroke) will make you fail california smog..
post Jun 22, 2004 - 4:24 PM
Junior
Joined May 5, '03
From Toronto
QUOTE (KAMiX @ Jun 22, 2004 - 12:11 AM)
actually, you need to do some research. A bigger bore doesn't do jack with compression. If you get pistons with a convex top, then'll you increase compression, but the bore has nothing to do with it.
post Jun 22, 2004 - 7:26 PM
KAMiX
Joined Mar 4, '03
Actually, YOU need to do some research. Don't mean to be rude but you are wrong Junior.
Compression is based on the size of the combustion chamber with the piston at the bottom of it's cycle (Max chamber size) vs size of the chamber with the piston at the top of it's cycle (min chamber size).
So if you increase the bore & keep the min chamber size the same with bigger pistons, you will increase your compression. You are right in that you can also just change the shape of your piston heads to only reduce the min size of the chamber, but that is not the only way to do it.
Heres a good link that shows you how to calculate ur compression ratio. http://e30m3performance.com/myths/more_myt.../comp_ratio.htm
post Jun 22, 2004 - 11:03 PM
Junior
Joined May 5, '03
From Toronto
Learn to do some math. When you bore it out, the combustion chamber is bigger at the top and bottom of the cycle, not just the bottom of the cycle.
post Jun 23, 2004 - 3:11 PM
celicasupra209
Joined Mar 30, '04
From cali
well my future ideas is possible Supercharge from rippion and modifiying my hood (gt4) to fit the supercharger tongue.gif.. so what would i need to make it strong enuff to handle that kind of power guys.. bore/stroke is a diffinete yes. does anyone know how much our stock piston/rods/crans can handle? hp wise that is and i looked up stuff but cant find any pistons and so on to fix my car up.. what the heck! lolz im also looking into a clutch kit.
post Jun 23, 2004 - 8:52 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
If you planned on getting the Ripp Mods Supercharger for the 5SFE, your stock engine internals would be fine. Getting a heavier duty clutch would be a good idea to handle the extra power, but supercharging wont immediately require any extra internal work, unless somewhere down the road you have the money to get forged pistons and rods, along with new valves and valve seals.
But thats only really neccesary if you plan on turniing up the boost significantly. Staying on top of engine maintainence and not running lean is your best prevention against things going wrong. This, to the best of my knowledge, will set you on the right path to keep your engine running reliably. wink.gif
EDIT- Increasing the bore and stroke will not in any way strengthen the engine. Your crank has plenty of strenth to deal with boost at least to a humane level, however getting stronger and lower compression pistons and forged rods would probably be a wise upgrade when dealing with lots of boost, along with new or aftermarket valve springs and seals.
This post has been edited by Silver94CelicaOwner: Jun 23, 2004 - 8:58 PM
post Jun 24, 2004 - 2:34 PM
celicasupra209
Joined Mar 30, '04
From cali
wow thanks guys for the 411. Now i just gotta go find a place to hook me up with some stuff! i was also researching the carb stuff about internals changes..
"Replacement internal engine parts, such as pistons, rods, or the crank, must be designed to factory specifications. Oversize parts can be used as long as they are within factory tolerances for replacement engine parts. Any part not built within factory specifications requires an Executive Order to be legal for street use"
so lets see if i plan in supercharging it with possible higher boost the what Ripp mods are stating i should beef up my internals. I guess im going to bore/stroke out my internals and if my funds are enuff get some new forged piston, etc.
does port polishing help any? at all?
post Jun 29, 2004 - 10:23 AM
celicasupra209
Joined Mar 30, '04
From cali
Where can i find some kits i can purchase to save money buying individually?
post Jul 2, 2004 - 11:09 AM
celicasupra209
Joined Mar 30, '04
From cali
what would you guys recommend me purchasing, for to build the bottom end for future supercharging? (ie: je pistons over hp pistons). My uncle recommended only going 30 over bore?
im trying to buy materials to install on my now dismantel engine.
Also does lowering my compression affect the power output, such as losing hi-end trq and so on.
DAMN I HATE BEING A NOOB.
wish i could just put a program in my brian like "matrix" and have all the knowledge.. tongue.gif
post Jul 2, 2004 - 12:39 PM
SlowCelica94
Joined Sep 28, '03
From Bloomington, IN
Wow, when I about to read this thread I really thought it would end in, "Then she said, ' get me towel'"
92 Civic hatch B16 - Sold
10th anniv RX-7 - RIP
post Jul 2, 2004 - 12:46 PM
shid
Joined Jan 8, '04
From LA
Don't lower your compression with pistons until right before you turbo/super, because it'll slow down an NA like nothing else.
This post has been edited by shid: Jul 2, 2004 - 12:46 PM
post Jul 2, 2004 - 2:06 PM
SlowCelica94
Joined Sep 28, '03
Then you have killer turbo lag. What to do about that? Let's ask Andason
post Jul 2, 2004 - 2:27 PM
shid
Joined Jan 8, '04
From LA
What? Lowering the compression on NA engines will bog them down, but its better for a turbo to have lower compression- what are you talking about?
post Jul 2, 2004 - 2:34 PM
SlowCelica94
Joined Sep 28, '03
I agree. But b4 the turbo spools up, you're running all off ur n/a power. And if you lower the compression, it'll take even longer to spool up. It's not really a big deal, it's only a few grand
post Jul 2, 2004 - 2:49 PM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
QUOTE (Junior @ Jun 22, 2004 - 9:03 PM)
Larger displacment means more air coming in on the intake cycle, which means more air being compressed at tdc, which my friend means higher compression.
And the link Kamix posted just proves both our points.
This post has been edited by Uppitycracker: Jul 2, 2004 - 2:54 PM
post Jul 2, 2004 - 2:52 PM
shid
Joined Jan 8, '04
From LA
Actually, you're running off worse than NA power- NA power alone isn't enough to suck in air into the engine- and thats why you have "vacuum" at the bottom of boost guages. Compression rarely effects turbo lag- rather, it has a strong effect on wether your engine blows up- and at what psi.
Lo-Fi Version Time is now: August 26th, 2026 - 9:50 PM
