> cold air intake problem
post Jun 21, 2004 - 3:32 PM
OrbitalGT95
Joined May 3, '04
From pittsburgh
is it possible for the engine to be running funny after u install it, cause i put one on and now at the low gears and rpms it's being boged down, almost sounds like it's gonna stall. anway...could the mixture be to lean or is it's something like the fuel filter or something else all together??..thanks for the help
Now SR powered
Replies (1 - 5)
post Jun 21, 2004 - 9:26 PM
3FingersCelica
Joined Aug 21, '03
From Endicott NY
Does not sound like a problem with your intake. Not sure what it is but definately not the intake.
post Jun 21, 2004 - 10:09 PM
95STHATCH
Joined Jun 21, '03
From FRANKFORT,KENTUCKY
Check your vacume lines,cause you knocked one lose or off.
post Jun 21, 2004 - 11:43 PM
KAMiX
Joined Mar 4, '03
Yeah and it's possible (although I don't think so) that not having the air sensor plugged in is causing it. I have run my car fine without but some people have said it's messed with their A/F ratios.
post Jun 21, 2004 - 11:46 PM
latinomasfino
Joined Feb 17, '04
QUOTE (KAMiX @ Jun 22, 2004 - 4:43 AM)
yea i agree same thing happen to my friend plus he had to spend more money on gas soo if u didnt plug in ur oxygen senor correctly i suggest u do that
post Jun 22, 2004 - 12:39 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (latinomasfino @ Jun 22, 2004 - 4:46 AM)
It's not an air sensor or oxygen sensor... it's a temperature sensor... however... you guys are probably correct about it causing the bog downs. It can potentially mess up the air/fuel mixtures by reading incorrecty (engine bay temp vs. intake temp) and slighty alter the ignition timing... but who knows for sure...
Lo-Fi Version Time is now: May 8th, 2026 - 2:42 AM
