> Almost Back to Normal, Harden Bodykit?
post Jun 22, 2004 - 11:56 AM
Guest_DJMC_Celica_*
Well over the past few days i have been slowely fixing my car back to normal! I put all my turn signals back in! Still am working on the LED thing, but.....
a friend of mine said "why dont you just pack bondo in all the holow places of your kit! so when u hit a curb it doesnt shatter!?" I know nothing about bondo? Just curious if this would work?
Thanks guy and gals!
DJMC
Replies (1 - 13)
post Jun 22, 2004 - 12:02 PM
IDK what ur kit made up of, but im going to reply assuming its fiberglass. In which case when you or if you hit something, it doesnt shatter. It can be described as a tearing. Since its fibers, its "woven" together and so it cant shatter.
post Jun 22, 2004 - 12:25 PM
shid
Joined Jan 8, '04
From LA
DJ, that might work... it'll certainly add some strength to it I think
post Jun 22, 2004 - 10:41 PM
Guest_DJMC_Celica_*
Does anyone, think this is a good idea? Or anything else anyone can think of to use?!!!?? at least i know it sounds maybe like a way to harden our kits. And yes i have a fiberglass kit! Thanks guys
post Jun 22, 2004 - 10:43 PM
moltar
Joined Mar 31, '04
From Cincinnati, OH
Bondo for sure.
post Jun 22, 2004 - 10:48 PM
Guest_DJMC_Celica_*
They why isnt anyone doing it??? or are they and just not talking about it?
post Jun 22, 2004 - 10:55 PM
dude i kinda did this, i cracked my front lip of the vader kit, and i re fiberglassed it back together then BONDO with FIBERGLASS strands IN IT. the backside of it, made it much stronger i accidentally nicked the street with that exact same spot just a lil scrapage and no tare or rip
post Jun 22, 2004 - 10:56 PM
shid
Joined Jan 8, '04
From LA
maybe it causes fitment issues?
post Jun 22, 2004 - 11:00 PM
boosted_K2
Joined Aug 30, '02
From Michigan
dont fill it, all you will do is blow a ton of cash on bondo. a better idea is to use some tiger hair fiberglass compound (which is chopped fiberglass that is in a bondo compound) to add a layer or two to the backing would definatly help strengthen against cracks.
No but I don't buy it
Cause I'm...
post Jun 22, 2004 - 11:16 PM
Junior
Joined May 5, '03
From Toronto
What i did with my kit was fill the inside of the lip with fiberglass. I used the resin and hardner and poured it in. Ruff up the inside of the surface first.
post Jun 23, 2004 - 5:12 AM
KAMiX
Joined Mar 4, '03
Yeah you can also just use some kind of foam or other filler to just fill the space. If you something to hold the shape of the fibreglass it will be more likely to flex than snap. Maybe some sort of expanding foam spray could work.
post Jun 23, 2004 - 7:18 AM
QUOTE (boosted_K2 @ Jun 23, 2004 - 12:00 AM)
i thought it was called gorilla hair?
post Jun 23, 2004 - 7:33 AM
this is why i hate fiberglass and dont think it should be used for body kits. the main problem is that fiberglass dosnt flex like polyurathane does. so when you hit something it will just crack your kit.
post Jun 23, 2004 - 9:03 AM
Guest_DJMC_Celica_*
Who ever the idiot was to think of fiberglass kits, should be beaten with a metal poll by midgets!!! hahaha sorry got a little ahead of myself there!
Lo-Fi Version Time is now: August 25th, 2026 - 6:16 AM
