Jun 22, 2004 - 5:55 PM
Enthusiast Joined Mar 23, '04 From RI Currently Offline Reputation: 0 (0%) |
i have a squeeking noise coming from my driver's side front tire and a weird thunking noise when I turn semi-hard to the right...not sure which tire that is. brakes are disc in front and drum in rear. the brakes were serviced all the way around about 7-8 months ago. I recently came back from a 2 week long trip and its been really bad. any ideas?
Jun 22, 2004 - 9:39 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 16, '04 From San Diego Currently Offline Reputation: 0 (0%) |
Does the noise happen when you brake?
Jun 22, 2004 - 10:43 PM
Enthusiast ![]() ![]() Joined Mar 2, '04 From Louisiana, USA Currently Offline Reputation: 2 (100%) |
My car was making the following sounds; a low speed squeak (persistent under braking) that went away at about 35mph, and the horrible grinding/clunking around corners. The problem was wheel bearings. I also replaced my right side ball joint, as it was worn out. Jack up your car and take a look at the ball joint boots, and also check for any play in the hubs by pulling on the wheel (or removing the wheel and directly checking the hub).
If it is your bearings, have a shop do them unless you can get to a good press. Cost was about $110, and it took me all day due to one inner bearing race being extremely difficult to remove. The rest of the pressing operations took perhaps 45 minutes. |
Jun 23, 2004 - 10:21 AM
the squeeking happens just when i'm driving until about 40 but i took off the driver's side front tire, messed around with the rotor and put it back on tightly and that seems to have fixed the squeek somehow...but the clunking is still there...fairly new to this so I'm not sure what to look for but i have a chilton's manual so i'm gonna check that out...but could it eb anyhting else besides the wheel bearing? its only when I turn semi-hard/hard to the right it almost sounds like someone hitting a big plastic drum filled with sand if you can imagine that lol
thanks for the help, -C |
Jun 23, 2004 - 10:25 AM
Do you have coil-overs or lowering springs? Either of those can cause clunking when turning.
Jun 24, 2004 - 4:23 PM
nope just stock susp.
-C |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 4:56 PM |
