Jun 24, 2004 - 5:06 PM
Enthusiast ![]() ![]() ![]() Joined Oct 3, '02 From bonzaisushi@hotmail.com Currently Offline Reputation: 0 (0%) |
im gettin some blue smoke when i start the car, but only when i start it.. does that mean my valve seals are bad? and what are valve seals?
Jun 24, 2004 - 5:11 PM
yeah valve seals, its notorius with the 5sfe go on the rav4 boards. the valve seal cant keep a good seal so very small amounts of oil with drip down eventually into you cyclinder(s) and on start up be consumed.
i have it, sucks. when i have time college and all i plan to replace them and my valve springs with 2jz ones. This post has been edited by x_itchy_b_x: Jun 24, 2004 - 5:19 PM -------------------- |
Jun 24, 2004 - 5:29 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) |
I've got it too.. Itchy, whats this about replacing them and the valve springs? Could you go into more detail?
Jun 24, 2004 - 5:44 PM
Enthusiast ![]() ![]() ![]() Joined Sep 22, '03 Currently Offline Reputation: 0 (0%) |
I have it also
Jun 24, 2004 - 8:16 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
I have it also... damn old seals.
Jun 24, 2004 - 9:21 PM
Enthusiast ![]() ![]() Joined Mar 2, '04 From Louisiana, USA Currently Offline Reputation: 2 (100%) |
Same here. I remember reading something a while back that the valve stem seal problem was pretty widespread in all "F" head Toyota engines, but that may have been speculation...
Jun 24, 2004 - 9:55 PM
its not, my mom's minivan has it too
Jun 24, 2004 - 10:52 PM
well i read somewhere that tehy are stonger than ours.
Jun 24, 2004 - 10:57 PM
well of course they are, but specifics man! they're interchangable? what are the valve stems? edumacate me!
Jun 25, 2004 - 12:07 AM
supposedly, im still gunna do sum reasearch before i say sumthign stupid. but yeah the valve stem is the narrow rod on the valve that is connected to the head of the vavle. hard to explain with out pictures lol. if this T was a valve the bottom line would be the stem -------------------- |
Jun 25, 2004 - 12:22 PM
Yeah itchy, fill us in when you find out info about replacing and maybe better seals out there for us.
Jeremy |
Jun 25, 2004 - 4:07 PM
I have it also, any way of getting rid of it?
Jun 25, 2004 - 5:52 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
one thing is for sure, theres no cheap fix for it, ive tried quite a few of the stop smoke bottles
Jun 26, 2004 - 2:18 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
oh the blue smoke problem.
My dads s-10 has the same problem, as the engine heats up the valve seals expand and the oil leak dissappers. The sad thing is the engine only has 99,500 miles on it. The only way to fix this problem is to change the valve seals, but this doesnt last very long either because the valve stem seat has worn down and starts to wiggle over time; this causes the valve seals to wear down faster and the leak returns. I had to change valve seals 3 times on differnt cars. its a bitch to do. |
Jun 28, 2004 - 2:54 AM
Enthusiast ![]() ![]() ![]() Joined Feb 27, '04 From Illinois Currently Offline Reputation: 1 (100%) |
So eventually, would you be losing oil? Because mine does the same thing, and it prolly takes a month or so before I notice my oil is down. My dad says I have scarred cylinders and oil leaks through the scratches. But this seal problem that you're talking about seems feasible also.
Jun 28, 2004 - 3:23 AM
well, if the valve seals continue to degrade then you will start to burn oil continously, and you will eventually lose oil.
Jun 28, 2004 - 3:29 AM
This seems like a pretty common problem? Is there any recalls on any parts of the F series motors?
Jun 28, 2004 - 3:36 AM
actually its a real common problem in ALL cars..
not specifically the f motor. |
Jun 28, 2004 - 3:39 AM
Is it just a "ware and tear" thing, or is it caused by rough driving, or both?
Jun 28, 2004 - 3:46 AM
From what I have seen are these seals start to harden up over time. When they get to the point where they no longer can seal the moving valve stem, oil gets in.
So I assume its from wear and tear? I dont exactly know the reason. |
| Lo-Fi Version | Time is now: May 7th, 2026 - 8:21 PM |
