> Serpentine Belt, what the heck is the problem
post Jul 2, 2004 - 9:45 AM
Tru_Pol
Joined May 3, '04
From Alhambra 62001
Ok so last month my serpentine belt started to go. So I went and got a new one. Since then I cannot not keep the belt tensioned and it will start to squell. I keep having to loosen the bold on the Alt and putting tension on the belt then tighten it done. Last week I ended up snapping the bolt and ran to the store to buy a new bolt. This week (today) it started to squell bad I made it a mile and it stoped, about 3 miles later my engine was smoking. Had to turn around and drive home only to find out the belt snapped in half, from the pully turning it and not turning the belt it burned it in half, and becouse my water pump and everything else was not turning the top of my radiour (sp?) blew off. Now when I replace the belt (again) what do I need to do to make sure it done not get loose, I mean I crack the heck out of the bolt and it does not last.
Im going to replace the radiour and all the pipes too!
What a mess!
Jason
post Jul 2, 2004 - 10:01 AM
macavely
Joined Nov 4, '02
are you using a tq wrench? if not please do... always do when it's anything on the engine .. and get the right numbers..
make sure you are using the rite belt for the eninge.. as in year of the engine.. on sometime they get moves a little from year changed engines...
make sure all you pullys are correctlly installed... and nothing it's touching the belts...and that they are turning properlly
and make sure you have the belt installed correctlly some times it's easy to miss a loop..
post Jul 2, 2004 - 10:05 AM
Tru_Pol
Joined May 3, '04
From Alhambra 62001
The belt came from Toyota, so I would sure hope its the right one.
I did use a TR for the first time I tighted the bolt, but like I said, it was not tight enuff.
I did put it one right, the alt just keeps comming loose and that will loosen the belt.
post Jul 2, 2004 - 10:33 AM
macavely
Joined Nov 4, '02
i forgot but do the pullys on the 7a have lips on them..
post Jul 2, 2004 - 11:06 AM
Tru_Pol
Joined May 3, '04
From Alhambra 62001
QUOTE (macavely @ Jul 2, 2004 - 3:33 PM)
I dont remember off hand, but I dont think so.......why, whats the thought?
post Jul 2, 2004 - 11:10 AM
macavely
Joined Nov 4, '02
cause if they do have lips.. one could have been damaged.. cause the belt to slip.. or causing it to ride on the lip and strching out the belt..
post Jul 2, 2004 - 11:19 AM
Tru_Pol
Joined May 3, '04
From Alhambra 62001
QUOTE (macavely @ Jul 2, 2004 - 4:10 PM)
I went out and looked and yes it does have the lips and I get what your saying but, thats not my problem. I can tighten the bolt down, and when I run under 3000 RPMs its fine, but when I go over that its starts to loosen. Almost like the pully is pulling to hard. Does that make sense? I can do about 40 miles before the belt gets to a point that it too loose and I need to undo the bolt and loosen it down again.
J-
post Jul 2, 2004 - 11:50 AM
macavely
Joined Nov 4, '02
maybe the first time you put the belt on you strched out the bolt causing it not to hold when the pully started to spinn pass 3k
post Jul 2, 2004 - 12:04 PM
Which bolt are u tightening? There should be 3. I have a 5sfe but the set up for the alternator should be the same. Theres one bolt for the bottom connecting the tensioner bracket to the block, one connecting the alternator to the rectangular piece with 2 holes tne the bracket, and finally the long screw which goes into the rectangular piece which tightens things up.
post Jul 2, 2004 - 1:16 PM
Tru_Pol
Joined May 3, '04
From Alhambra 62001
QUOTE (Supersprynt @ Jul 2, 2004 - 5:04 PM)
The long bolt that is holding the Alt on. Its the only one for the main serpentine belt that I can find that tightens the belt. Im almost wondering if there is something missing? The car was betten on before I got it.
J-
post Jul 2, 2004 - 6:22 PM
Rjb23
Joined Feb 8, '04
From KY
First off your doing it wrong. You have to loosen the bolt that holds the alternator on so the alternator can move freely. Then you use the tension belt to put enough tension on the belt, then you retighten the alternator bolts to hold it in place. The tension bolt is just that meant to put enough tension on the belt not to hold the tension. What is happening is that bolt is working its way loose, and the belt is getting loose.
post Jul 3, 2004 - 4:42 PM
Tru_Pol
Joined May 3, '04
From Alhambra 62001
QUOTE (Rjb23 @ Jul 2, 2004 - 11:22 PM)
What tension belt are you talking about? The only thing I can figure out is to loosen the alt and that is what causes you to put tension on the belt.
Can you explain more?
J-
post Jul 3, 2004 - 5:46 PM
boosted_K2
Joined Aug 30, '02
From Michigan
there should be a fourth bolt that locks your alternator adjustment screw into place, see if that is missing. its perpendicular to the adjustment screw and located right above the belt. if its there, try tightening it after its adjusted, if it isnt, try replacing that. also doublecheck the torques on the pulleys and make sure there is no excess grease or oil on the pulleys or the belt.
No but I don't buy it
Cause I'm...
post Jul 3, 2004 - 7:02 PM
Rjb23
Joined Feb 8, '04
From KY
Ok let me see if I can explain this better.
On the top of your alternator there is a bolt that holds the alternator in place. On the bottom of the alternator this a longer bolt perpendicular to the one on top, the bolt on the bottom is used to put tighten or loosen the belt, the one on top of the alternator is used to hold the tension on the belt once the proper tension is put on the belt. The one on the bottom you will see pretty easy, its the long one that is connected to the block on the slider bracket. It has been a while since I have done one about a year or so, but there should also be a bolt that holds the block in the slider bracket in place. So basically loosen the top alternator bolt, then the one in the slider bracket, then you can adjust the tension on the belt using the long adjusting bolt. Once you have it tight enough, you should be able to push down on the belt fairly hard and move it about an half inch, tighten the other bolts back up and that should be it.
If you still can't figure this out, go to an auto parts store get one of the manuals off the shelf and look in it. You really need to get a manual anyway if your gonna do this kinda stuff.
post Jul 5, 2004 - 6:59 AM
Tru_Pol
Joined May 3, '04
From Alhambra 62001
QUOTE (Rjb23 @ Jul 4, 2004 - 12:02 AM)
That bottom bolt is missing! I was wondering about that. Its got some bracket but no bolt.
Thanks
J-
post Apr 22, 2016 - 2:00 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
mehh bump. no google search came up.
i went to toyodiy, toyotamarket ru, jp car parts but no luck finding 3sge beams serpentine belt. and I know its not the same as 5sfe (because part # doesn't cross reference to 3sgte or 3sge)
so should i just get any standard 5sfe serpentine belt? or use a 2nd gen 3sgte belt. obviously torque is slight different between beams and 5sfe. for you guys who has done 250-300whp 5sfte did you change out this serpentine?
saw a $36 serpentine gates belt on rock auto. just saying. and most low end cost $7-10
Lo-Fi Version Time is now: September 11th, 2026 - 12:56 AM
