Jul 9, 2004 - 11:32 AM
It's going to be cheaper and easier to rebuild your 5S-FE(to factory specifications...I'm assuming that's what you'd do, or are you thinking more performance?)
That said, the 3S-GTE will provide you with more power(unless you rebuild the 5S-FE and put tons of money into it to get the 3S-GTE's power, in which case you'd be spending more money than doing a swap.) If you've got the money, time, and dedication, and you want a turbocharged car, I'd say go with the 3S-GTE. -------------------- New Toyota project coming soon...
Jul 9, 2004 - 12:08 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) |
Well coom, you can actually get just the same out of 5sfe engine if you spend the same on a swap and have it done for you, while doing ll the 5sfe work yourself- or having very little done by other people... spend roughly 2k on turbo, and 2.5k on engine internals, and you'll have an engine pushing out 3sgte levels.. UNFORTUNETLY it will only go a little higher- the 3sgte has much more top end.
Jul 9, 2004 - 12:46 PM
(So, 3sgte is the better deal)
Jul 9, 2004 - 12:54 PM
Ok prices? with a "Excellent" mechanic what do you think? time frame estimate?
Jul 9, 2004 - 1:02 PM
So you're taking it somewhere? I'd say that you'd probably spend $2.5-4,000 on the front clip and parts, and then I'd guess $1,000-3,000 for labor.
I suggest asking around in your area. -------------------- New Toyota project coming soon...
Jul 9, 2004 - 1:04 PM
do what im doing. im buying the performance block from these guys. here for only $1399 then getting a clutch and turning up the boost to 12.
i might have to get larger injector well see. -------------------- |
Jul 9, 2004 - 1:19 PM
What are putting out in Torque and HP?
| Lo-Fi Version | Time is now: August 25th, 2026 - 8:34 PM |
