> Werid Noise, In back
post Jul 9, 2004 - 3:22 PM
drdos
Joined Aug 19, '03
From Buffalo,NY
I have a 94 coupe. and every time i go over bumps it makes a weird clunking noise in the back. I have nothing in my trunk at all not even the spare tire. all i have back there is the carpet. And every time i get out of my car or shake my car in the back it makes a werid squeeking noise. Has any one else had this problem b4. and if so what did you do about it?
Thanks for the help.
post Jul 9, 2004 - 3:42 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
this needs to be in the suspension forum ...........
Upper bushings in the rear, I had the same problem before. Quick and easy 20 dollar fix. It only comes from one side correct?
post Jul 9, 2004 - 3:51 PM
What upper bushings are you talking about?
post Jul 9, 2004 - 3:56 PM
Tressa95
Joined May 20, '04
From West Chicago , IL
I had that with my car and it was a bad strut. The noise went away after I changed my suspension.
post Jul 9, 2004 - 4:34 PM
Exile04
Joined Aug 20, '03
From Seattle, Washington
yai have that same problem going on right now how can i fix it.
post Jul 9, 2004 - 10:28 PM
hyp3rk1d
Joined Sep 22, '03
I believe you have to change your sway bar bushings and that should do it
post Jul 9, 2004 - 10:47 PM
slipgun
Joined Jun 2, '03
From Annandale VA
sure your jack is out or in tight?
post Jul 9, 2004 - 11:51 PM
I have a kind of clunking from the driver's side rear also. I just got my car aligned yesterday at Sears and they told me my sway bar link - not bushing - needed to be replaced. He described it as a "ball and socket" thing. They then quoted me a laughable price of $90 for the part and $40 for labor. I need to look into getting both sides replaced soon.
anyone have some info on this ?
post Jul 10, 2004 - 10:07 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
Yes, it could be the sway bar bushings (most likely), Sway bar End Link, or the strut. I have had this same problem. I replaced the struts and it still made the noise so i replaced the rubber sway bar bushings (4$ each, need two) and that was it!
The first thing i would replace would be the bushing because they are only like 4$ each at advanced auto parts.
Also, the end links are 48$ at advanced auto parts. Thats the cheapest place i could find them.
This post has been edited by bufferdan: Jul 10, 2004 - 10:09 AM
post Jul 10, 2004 - 10:35 AM
turboinduction
Joined Feb 25, '04
From Wisconsin
QUOTE (Coomer @ Jul 9, 2004 - 8:51 PM)
sway bar
and just like bufferdan said - its a cheap fix. If it is bushings, you should be able to go to the bad side and press on the fender and bouce it to cause noise. Just a squeek.
post Jul 10, 2004 - 4:24 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
i couldnt get the noise when i press on the back. I actually had to drive the car over bumps.
post Jul 16, 2004 - 12:15 AM
Tweek
Joined May 4, '04
From Panama City Beach, FL
I had something like this, and it took me forever to find that the tail light was making the noise. Loose connection.
Lo-Fi Version Time is now: May 19th, 2026 - 11:21 AM
