> Invader body kit install, How to??
post Jul 12, 2004 - 2:21 PM
ROBWOZ1018
Joined Oct 21, '02
From Pittsburgh
Well its time to put on the kit...I was wondering if anyone has any good info or knows of any instructions or diagrams that can be obtained on the web...I noticed the front of the sideskirts will need slight modification...Im also not sure how to go about molding pieces in...If anyone can help me out here?...Thanks Rob
post Jul 12, 2004 - 10:28 PM
sapperk
Joined Mar 9, '03
From Orting, WA
look at the pics in my profile, they might help you out. Lots of BONDO, lots of it... your gonna have to do alot of cutting on the side skirts to get it to fit right, otherwise they hit when you open and close the door. line them up the way you want them then cut..lots of bondo and sanding. i spent a week molding and sanding to get a great curve. alos the front end is tricky. i removed my bumper bracket and bumper to get it to fit good. and again lots of bondo around the headlights and the turn signals....the pics say it all..
post Jul 13, 2004 - 6:20 PM
97Celica
Joined Nov 27, '02
From Derry,NH USA
Not to be a jerk of anything,but,Sapperk probably bought a bad quality kit. I used ViS and had my kit on in a little less than 2 hours.Also,taking off your front brace is SUICIDE...you need to just customize it a little. PM me if you want my cellphone #
post Jul 13, 2004 - 9:04 PM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
I just put on the kit a few weeks ago, so here is my 2 cents worth:
The front is gonna take a little work... You'll need to trim the corners of the metal reinforcement for the kit to fit over it. In fact you will also need to trim out the main opening of the front for it to fit nicely over top of it.
On the sides, I cut off the top lip at the bend because I wanted the plastic trim that goes inside the door to still fit.
Unless you plan on making your car a trailer queen show car, I don't recommend molding in the kit. Daily driving and temperature changes constantly make the metal of the car move slightly and will crack the kit over time. I didn't mold it in and the kit looks great.
When I get more time I'll try and post some more.
Ryan
Lo-Fi Version Time is now: June 17th, 2026 - 1:49 PM
