> 7ATFE, For all the ST's that are turbo'd
post Jul 13, 2004 - 7:28 PM
Ant_96_ST
Joined Jan 4, '04
From Mt. Vernon, NY
Before you guys put on your turbo kits, what things did you do to your engines to keep running safely. I'm seriously considering turboing my car at 4-6PSI regularly and occasionlly using an 8PSI as a high boost. What kinds precations should I take for this boost level??
- Ant_96_ST   7ATFE   Jul 13, 2004 - 7:28 PM
- - shid   Just keep it up to date maintance wise; make sure ...   Jul 13, 2004 - 7:47 PM
- - nik   hey shid when you finally going to turbo your car?...   Jul 13, 2004 - 8:43 PM
- - shid   When I start buying parts actually? hehe. done by ...   Jul 13, 2004 - 8:47 PM
- - nik   http://www.cardomain.com/memberpage/521899/2 last ...   Jul 13, 2004 - 8:54 PM
- - turboinduction   nice nik my Celica-T begins November. from there...   Jul 13, 2004 - 9:09 PM
- - shid   6 months?? Taking your sweet time. I expect to st...   Jul 13, 2004 - 9:12 PM
- - nik   now look a few more pics the manifold might powder...   Jul 13, 2004 - 9:20 PM
- - shid   Ahh, you do have a FMIC, my mistake Nice job avoi...   Jul 13, 2004 - 9:22 PM
- - Ant_96_ST   Do I need forged pistons and rods??   Jul 13, 2004 - 9:32 PM
- - shid   For 6 psi? hellz no   Jul 13, 2004 - 9:53 PM
- - Ant_96_ST   And if I put it up to 8psi occasionally is that st...   Jul 13, 2004 - 9:54 PM
- - shid   every now and then it SHOULD be fine. I'm not ...   Jul 13, 2004 - 10:00 PM
- - forkee   QUOTE (shid @ Jul 13, 2004 - 5:47 PM) Just keep it...   Jul 13, 2004 - 10:19 PM
- - nik   hey forkee you ever dyno your car?   Jul 14, 2004 - 10:37 AM
- - FallenHero   turboed 7a's make between 160 and 180 whp. th...   Jul 14, 2004 - 11:19 PM
- - forkee   QUOTE (nik @ Jul 14, 2004 - 8:37 AM) hey forkee yo...   Jul 14, 2004 - 11:32 PM
- - shid   Forkee, those don't work that well- and it sti...   Jul 14, 2004 - 11:41 PM
- - MK153   How much does this run to turbo the car? I cant re...   Jul 15, 2004 - 2:04 AM
- - nik   i'm about $1850 deep so far not bad a kit...   Jul 15, 2004 - 9:11 AM
- - zipstrips   nik: nice to see my turbo kit is working out for y...   Jul 15, 2004 - 9:42 AM
- - nik   ya i can get it in the mail probably monday or so ...   Jul 15, 2004 - 11:22 AM
- - edo17982   QUOTE (nik @ Jul 14, 2004 - 3:54 AM) http://www.ca...   Jul 15, 2004 - 1:26 PM
- - nik   QUOTE (edo17982 @ Jul 15, 2004 - 11:26 AM) QUOTE (...   Jul 15, 2004 - 1:32 PM
- - nik   got it dyno at 5.5 pounds for now results: 131.3 h...   Jul 16, 2004 - 3:48 PM
- - Hanyo   hmmm after all those dyno runs you must run it on ...   Jul 16, 2004 - 6:32 PM
- - RedSunCelica   QUOTE (nik @ Jul 16, 2004 - 1:48 PM) got it dyno a...   Jul 16, 2004 - 6:59 PM
- - zipstrips   QUOTE (nik @ Jul 15, 2004 - 9:22 AM) ya i can get ...   Jul 16, 2004 - 7:41 PM
- - zipstrips   nik, your numbers will climb, look at my dyno in m...   Jul 16, 2004 - 7:43 PM
- - shid   Nik, tight numbers! especially the torque. Now...   Jul 16, 2004 - 7:49 PM
- - FallenHero   why do you want to change your compression? what ...   Jul 16, 2004 - 11:15 PM
- - 97sccelica   QUOTE (FallenHero @ Jul 16, 2004 - 8:15 PM) why do...   Jul 17, 2004 - 9:57 AM
- - nik   my goal is 8 psi.My engine is on the higher miles ...   Jul 17, 2004 - 2:21 PM
- - hyp3rk1d   I Cant wait until i get my setup all done.. I plan...   Jul 17, 2004 - 2:48 PM
- - celicaboston1983   a turboed st = 160 hp how much hp would a turboed...   Jul 20, 2004 - 11:59 AM
- - ArizonaRed   I had never modefied the compression ratio and kep...   Jul 20, 2004 - 12:45 PM
- - nik   QUOTE (celicaboston1983 @ Jul 20, 2004 - 9:59 AM) ...   Jul 20, 2004 - 1:44 PM
- - celicaboston1983   how much skills and money for this kind of project   Jul 20, 2004 - 1:46 PM
- - ArizonaRed   If you want to get the project done without half a...   Jul 20, 2004 - 3:00 PM
- - nik   QUOTE (celicaboston1983 @ Jul 20, 2004 - 11:4...   Jul 20, 2004 - 4:19 PM
- - nik   i got a bigger mid pipe between the D.P the before...   Jul 22, 2004 - 10:55 AM
- - DustyBurns30   here is a stupid question: i heard that i need a ...   Jul 28, 2004 - 9:29 PM
- - nik   QUOTE (DustyBurns30 @ Jul 28, 2004 - 7:29 PM) here...   Jul 29, 2004 - 11:48 AM
- - DustyBurns30   what is the purpose of it?   Jul 29, 2004 - 3:37 PM
Lo-Fi Version Time is now: August 9th, 2026 - 4:17 PM
