Jul 14, 2004 - 10:46 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 22, '04 From Rhode Island Currently Offline Reputation: 3 (100%) |
i have 17 inch wheels, if i were to put eibach pro line ( i think thats the 1 inch drop springs) would i needa camber kit... or just a good alignment.... im very picky when it comes to my car and it needs to be PERFECT. im considering lowering but i dont want uneven tire wear...... thanks-
Jul 15, 2004 - 7:41 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) |
Alignment will work fine.
Jul 15, 2004 - 2:06 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 25, '02 From Pittsburgh/Clairton, PA Currently Offline Reputation: 1 (100%) |
sportlines are fine too
they're 1.5" and would only need an alignment as well... edit: but if you want perfect i think performance struts and shocks may be in order to keep the ride quality in either situation. This post has been edited by Consynx: Jul 15, 2004 - 2:07 PM -------------------- ![]() |
Jul 15, 2004 - 4:25 PM
well i dont really have the money for struts and shocks... i dont mind a little bit more bumpier just as long as it isnt really bad and i still want the car to be safe and the tires to wear normally..... so the sportlines plus an alignment would be completely fine?
Jul 17, 2004 - 10:22 PM
Enthusiast ![]() ![]() Joined May 7, '04 From Concord, NH Currently Offline Reputation: 0 (0%) |
if you want the care to be safe then do it right the first time before your shocks die and you go over a bump and can't control your car well at all.
Dr. |
Jul 17, 2004 - 10:35 PM
It will be fine if your struts are fine. Being that your car is a 97' you probably dont have too many miles on the stock struts right? If you suspension feels like crap now you mise well upgrade it all at once.
Jul 19, 2004 - 2:58 AM
Enthusiast ![]() Joined Dec 5, '02 From Sacramento, CA Currently Offline Reputation: 0 (0%) |
Yes, just do it all at once... your going to eventually have to replace ur struts. Donīt be like me - I replaced the shocks because my tires were dying, and now i wish i had springs installed... would not have cost anything extra.
Ed. Edit: not shocks, struts This post has been edited by Makaveddie: Jul 19, 2004 - 2:58 AM |
Jul 19, 2004 - 11:55 AM
yeah first off do it all at once. Second, i would say go with the sportlinesn there norm cheaper an give you a lil better of a drop. Also.. I did sportlines with gr-2's.. and I didnt adjust camber or alignment and its fine.. you dont have to do an alignment or caber for this bit of a drop.. and alignment as long as you dont mess with any of your settings your fine. save your money.
Jul 19, 2004 - 2:27 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 25, '04 From Wisconsin Currently Offline Reputation: 0 (0%) |
I'd camber... but i'm a perfectionist.
Jul 20, 2004 - 7:46 AM
Enthusiast ![]() ![]() Joined Nov 29, '03 From Hampton, VA Currently Offline Reputation: 0 (0%) |
I'm thinking of using sportlines and gr2's with 18 inch rims. I know tire size will ultimately determine if it works, but does 18's with the drop of sportlines sound extreme or just right? I firgure the bigger the rim the further the suspension needs to be lowered to get rid of the monster-truck look. Any suggestions?
Jul 20, 2004 - 1:13 PM
Enthusiast ![]() Joined Jun 2, '04 From NYC Currently Offline Reputation: 0 (0%) |
a set of the kit sale on tirerack.com only $28 + shipping, since you want it perfect, why not get it, and a suggestion, ever think of the tein S. tech springs? alot people in here recommend it, I plan to put a set on my babe this weekend if all parts arrive on time, my plan is a set of KYB GR-2 and set of tein S tech, which get me 1.5 drop in the front and .9 drop in the back, and only around $350 plus installation... Cheap~
| Lo-Fi Version | Time is now: May 9th, 2026 - 12:25 AM |
