> valve gasket
post Jul 17, 2004 - 1:18 PM
Ok i don't know where i came up with this idea but what would happen if i took like THREE vavle cover gaskets and layered them on the engine....what would happen...compression? torque? i have no clue
post Jul 17, 2004 - 5:58 PM
Anub1s
Joined Nov 27, '03
Your valve cover gasket just keeps the oil in the head. It really doesnt have anything to do with compression or engine performance. As for HEAD gaskets you would probably FUBAR your motor. Everything internal is measured and made precise for a reason. You may want a second opinion on this but I am sure that it wouldn't be a good idea.
post Jul 17, 2004 - 10:21 PM
oops haha i ment a head gasket sorry
post Jul 18, 2004 - 8:19 AM
mikew04
Joined Feb 19, '04
From austin tx
They make copper headgaskets that are thicker, and it would lower compression. Id imagine that they make them for our cars as well. Its an easy way to lower compression if you want to turbo your motor without boosting high.
post Jul 18, 2004 - 10:31 AM
ok so i can try and find a thicker copper head gasket...but i'm staying NA for a while....what will that do to my HP numbers in lowering compression?
post Jul 18, 2004 - 10:38 PM
mikew04
Joined Feb 19, '04
From austin tx
you'll lose power
post Jul 18, 2004 - 10:43 PM
FallenHero
Joined Dec 26, '02
From Alabama
4age gaskets work. they make them from .5mm to 2.0mm I think.
post Jul 18, 2004 - 10:44 PM
how would i lose power? i'm not arguing the point just wanted to know the mechanics of it all.
post Jul 18, 2004 - 11:08 PM
chucho
Joined Mar 23, '03
From New Orleans
if you lose compression you lose power, it wouldnt be much (i'd imagine) but lost anyway. That turbo compresses and makes power. But NA setups use high compression pistons to make more power. Your low compression pistons would make less power but are needed w/ your turbo
Lo-Fi Version Time is now: March 29th, 2026 - 8:20 AM
