> quick question for 5sfe/3sgte guys, anyone w/ electronic oil pressure gauge
post Jul 18, 2004 - 11:24 AM
boosted_K2
Joined Aug 30, '02
From Michigan
can you snap a pic real quick of where you are supposed to mount this damn oil pressure sending unit that autometer provides? thanx.
No but I don't buy it
Cause I'm...
post Jul 18, 2004 - 12:09 PM
1bwilson
Joined Aug 30, '02
From Maryland
On the 5sfe its where the stock unit is. Looking at the engine its on the right side just below the valve cover. On your 3sgte it may be on the back half of the motor cause your placement of the motor.
Member of Team 5sfTe
post Jul 18, 2004 - 5:21 PM
boosted_K2
Joined Aug 30, '02
From Michigan
http://www.we-todd-did-racing.com/wetoddim...zMXk1NDE%3D.jpg
that one right there correct?
Cause I'm...
post Jul 19, 2004 - 12:28 AM
orvillescelica
im also installing an oil pressure guage and water temp gauge. So i just T off the stock pressure sending unit and install the new one?
What about the water temp. I searched and found conflicting feedback: one said there was already a hole for an aftermarket temp gauge, another said to T off from the stock temp sensor, andother said to make a T off of the hose and tap a hole for the new temp sensor. Which one is correct?
post Jul 19, 2004 - 11:25 PM
boosted_K2
Joined Aug 30, '02
From Michigan
w00t check it
Cause I'm...
Lo-Fi Version Time is now: July 11th, 2026 - 11:27 AM
