> Painting the REar Drums, is it safe?
post Feb 25, 2003 - 2:38 AM
H8DC3lica94
Joined Jan 29, '03
From San Diego, CA
I just put in Motegi 17' MR7 Rims. They look great and makes the car look nice. but they expose the disc brakes and the rear drums. The rear drums are rusted from bad maintenace of the previous owner. Any ways i wanted to knoe if its safe to paint the rear drum and what is a good paint to use.
Chris Malaqui
Non-running Celica
Replies (1 - 19)
post Feb 25, 2003 - 3:02 AM
forkee
Joined Nov 13, '02
From So Cal
its perfectly fine. make sure the paint can withstand high temps and ur set. they make paint specifically for this use. u can find it at any auto parts store. biggrin.gif
post Feb 25, 2003 - 8:31 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
Make sure you clean everything as best as you can otherwise you will risk rust coming off and having spots in your paint job.
post Feb 25, 2003 - 11:15 AM
boosted_K2
Joined Aug 30, '02
From Michigan
just spray the front, spray the back of them and you run into trouble.
No but I don't buy it
Cause I'm...
post Feb 25, 2003 - 11:25 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
IMHO painted drum brakes look good, but since they are drum brakes, personally, I wouldn't want to draw attention to them... I would just be worried someone might laugh. but like I said just MHO
post Feb 25, 2003 - 3:30 PM
Cragspider
Joined Aug 30, '02
From Franklin,Tn
I have mine painted and haven't had any problems. I need to go back and touch them up because I chipped them when I was taking out my struts.
Bryan
post Feb 25, 2003 - 8:00 PM
H8DC3lica94
Joined Jan 29, '03
From San Diego, CA
Thanks for the replys' I dont really want to draw attention to them but i dont want them to look rusty either. so black or maybe even blue will do.
some one suggested whit to match the rims.
Chris Malaqui
Non-running Celica
post Feb 25, 2003 - 10:58 PM
boosted_K2
Joined Aug 30, '02
From Michigan
sliver metallic looks best... just something to make them look clean and not draw attention at all, black is the other best bet
Cause I'm...
post Feb 26, 2003 - 12:20 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
I would just powder coat them... will last alot longer... dont have to worry about rust and you should be able to get them done for around 25 a rotor... at least thats what is costing me for my brembo ones.. but there just doing the center hub so it would be a little more to get the whole brake done.. but like K2 said DONT do the back side
post Feb 26, 2003 - 12:26 AM
Guest_Jason_*
Whats wrong with drums that you wouldn't want to attract attention to them? IMO they look better than the front.
post Feb 26, 2003 - 12:46 AM
FallenHero
Joined Dec 26, '02
From Alabama
I hope to have my drums go away in a year or so. Then I'll wory about painting stuff.
post Feb 26, 2003 - 4:46 PM
rlan214
Joined Dec 27, '02
From Sleep in Warren chill in clinton twp, works/school in detroit
QUOTE (jayi12-15psi @ Feb 25, 2003 - 9:25 AM)
im with him in this one
i only have 16 inch gts rims and friggin drum makes it look akward
post Feb 26, 2003 - 4:47 PM
rlan214
Joined Dec 27, '02
QUOTE (NEVERSTOP @ Feb 25, 2003 - 10:20 PM)
what kind of places does powder coating ?
post Feb 26, 2003 - 6:15 PM
macavely
Joined Nov 4, '02
clean it with a weirbrush and paint it the same color as the car and it safe you don't have to worry
post Feb 26, 2003 - 11:19 PM
boosted_K2
Joined Aug 30, '02
From Michigan
do a search for powdercoating and your area on google.
QUOTE: Whats wrong with drums that you wouldn't want to attract attention to them? IMO they look better than the front.
the reason for not attracting attention to them is because drums are econobrakes. not made for performance at all. have you ever driven a car with front and rear drums? unfortunatly alot of older cars came like this, they tend to not like to stop too well.
Cause I'm...
post Feb 27, 2003 - 1:55 AM
H8DC3lica94
Joined Jan 29, '03
From San Diego, CA
biggrin.gif Well i just painted them today and i think i did a good job on them. The final color i chose was chevy blue with 500 degree resistance. This was the only color closes to my sea-spray car color. I post pics soon.
Chris Malaqui
Non-running Celica
post Feb 27, 2003 - 2:29 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
Did you paint front and back or what?
post Feb 27, 2003 - 9:22 AM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
Paining them looks great. IO have a black car and I sanded off the rust with fine sandpaper and then spray painted them black. Looks great with my 16 GTS rims. Much better than the rusty crap before i painted them
post Feb 27, 2003 - 10:56 AM
CelicaQT
Joined Sep 29, '02
From Sterling Heights, Michigan
KiLis-Can't wait to see the turn out on your drums. How long did it take you? 2hrs tops?
I'm planning on doing mine this spring/summer when the weather prevails. Prolly go look for something metallic color. I just want to keep it simple...not too much color for me.
Is sanding them down hard? Or does it just depend on how rusted they are?
Does anyone else have pics they can post so we can see how your drums turned out?
post Feb 27, 2003 - 11:38 AM
rlan214
Joined Dec 27, '02
got pics ?
Lo-Fi Version Time is now: September 19th, 2026 - 2:00 PM
